[Z06] dual valve spring?
Old Jan 3, 2011 | 07:28 PM
z06 hellcat's Avatar
z06 hellcat
Default dual valve spring?
is it ok to put a set of dual springs rated for 660lift on a cam with about 580lift? im not sure if it will cause abnormal wear verses a lower rated spring.
Old Jan 3, 2011 | 07:40 PM
AU N EGL's Avatar
AU N EGL
why?
get beehive springs rated to .600 is more then enough spring.
Old Jan 4, 2011 | 06:56 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I love the idea of dual springs for insurance. But, why go with a spring rated for so much more lift than you need?
Old Jan 6, 2011 | 01:13 PM
Over-torque's Avatar
Over-torque
it will, in fact, cause unnecessary stress on the rest of the valvetrain and induce valvetrain instability. and eat a little power in the form of parasitic (frictional) loss. as to insurance, duals are just as likely to fail as a good beehive. most knowledgeable builders recommend the least amount of spring necessary to do the job.
www.ls1tech.com has a lot of expert advice in valvetrain components
Old Jan 6, 2011 | 07:09 PM
Z06ufgrad2002
A dual spring certainly can also fail. The benefit is the second spring in most cases does not fail at the same time and will keep the valve from dropping into the cylinder or banging into the top of the piston and possibly destroying the engine. You are much more likely to have major engine damage if you break a single spring.
To dual valve spring?
