Oil reading problem
Old Jan 6, 2011 | 07:19 PM
tracer1's Avatar
tracer1
There is nothing wrong with removing the intake or doing it the way in the video. I just didn't have the confidence of doing it with the swivels and wire. My luck, I would drop everything behind the motor, then have to pull the engine, LOL. I'm sure it may be pretty easy that way, just wasn't for me. This forum is great & what makes it great is that guys come up with different ideas for problems they and others have. I never criticize anyone for doing anything to their cars. I think some of the things they come up with are fantastic, I just don't have the nerve to do it. I had strong reservations about doing mine but did it any way. I surely don't expect everybody to do it just because I did. I'm glad I did, it was simple but to each his own.
Old Jan 6, 2011 | 07:28 PM
seoulbrooks's Avatar
seoulbrooks
To each his own..... We all own OUR vettes
The different methods are what makes the forum great....always learning something
We make the choice of what is "Best" for us......
Old Jan 6, 2011 | 07:40 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
If mine goes out again,,,first one lasted 79K,,,,I'm buying a new manifold AND cutting the cowling,,,,then I will need a new carbon fiber cowling,,,,won't I Honey?
Old Jan 6, 2011 | 07:45 PM
tracer1's Avatar
tracer1
Boy, I agree with that. Wish I had thought of it. BTW, you don't cut the top cowling, there is a fiberglass cowling below the top cowling that you can't see.
Old Jan 9, 2011 | 12:35 AM
Double G's Avatar
Double G
Changing intake seals is a great idea at your cars age. I made my own relocation kit. I also used a Buick brass switch.
Old Mar 3, 2011 | 02:07 PM
rks959's Avatar
rks959
Default Oil sending unit update
Finally replaced oil sending unit today and was actually surprised it wasn't as bad as i thought it would be.Was gonna try to replace without removing intake but just could not get to it from the back,it is very tight back there.Thanks to the forum i was able to find some really good informative post about the intake removal,including pics and step by step process that made the job a lot easier.Just want to say thanks for all of you that helped along the way.Thank You,Karey
Old Mar 3, 2011 | 04:27 PM
johnson-rod's Avatar
johnson-rod
I'm with ya. I couldn't get the sender out without removing the manifold. Tried for hours.
It was WAY easier to just remove the manifold. 1/2 hr.
Whoda' thunk?
BTW - apparently the manifold torque and gaskets are fairly forgiving. When I went to pull the manifold - the 4 middle bolts were only finger tight.
Old Mar 3, 2011 | 05:03 PM
rks959's Avatar
rks959
Yea,when i pulled my intake today the big vacuum hose on the back of intake didn't even have a hose clamp on it at all.
