Hello,In have a 99 FRC for almost 2 years 44,400 miles.Parked car last everything fine,this morning cranked up fine and runs fine.All the gauges working properly except oil pressure gauge reads 80 and DIC reads oil pressure 129 psi and does not change. Any help with this problem would be greatly appreciated. Thanks,Karey
Yeah, wrong forum but in fact, your oil pressure sender has failed. Common problem for the C-5's. I suggest that when you buy a new one, get a "brass" one if possible. You'll have to remove the intake to get to it which is easy to do or cut a hole through the cowling.
Very common problem with the C5. If you want to tackle it yourself, I have some Word files that discuss the procedure, as well as some files that talk about a sensor relocation modification. PM me your e-mail address if you want copies.
happened in my c5 needs a new sensor. bout 300 bucks at the dealer if memory serves me correct.
happened to me yesterday. posted earlier about it. looks like an easy fix. the youtube link posted above shows a guy putting it in in about five minutes. im giving it a shot in the morn. i got the part from the dealership in dallas for $57. ill let you know how it goes.
As indicated above you should make sure you are using a brass sender and not one of the aluminum ones. Pay close attention to the torque and do not over torque or you will be doing the replacement all over.......
We replaced 2 oil pressure senders in the last 3 weeks in two different cars. That video is a You can't get to the sender because the brake boaster pipe is over the sender. Not sure how he was able to do it without removing the brake boaster but we tried everything and came to the conclusion to remove the mainfold.
Also depending on where the clip is on the sender it may take you 2 hours just to remove the clip.There is a fear of dropping the old sender or the new sender when installing it. After that happy hunting...
Save you a head ache and do it right.
The clip is NOT BS because I removed mine in that method. There was no need to remove the brake booster line, you just have to get the oil sender socket under it. The clip took about 15 seconds to get the plug off. Used a dental pick and popped the clip free. If your afraird the sender will fall out of the socket use a small piece of electrical tape inside the socket. guarantee it does not just fall out. Had to do mine twice because the first sender I received was an aluminum piece of crap and lasted all of 4 days.
Well in my case I'm 0-2 when trying to do this clip/don't remove the mainfold trick. Both cars had the same issue. Clip was pointed the other direction and it was hard to get to it to pull it up.
I like to see a poll of the people that have done this trick.
I cut the hole in my cowling. Very simple & clean. Cutting the hole, replacing the sensor, & re-assembly cowling cover took about 30 minutes total. Works great & you actually see what you are doing.
I agree. Removing the intake manifold is the only sure way to mitigate all risks associated with replacing that little SOB. Cut the cowl? Not on my car! Removing the manifold also gave me the opportunity to clean things up and replace the 11 year old gaskets.
!st....you can't tell that a hole has been cut. I cut mime with a dremel, tapered the cuts so the cut piece fits right back in the slots. I then put 1 strip of black gorilla tape over it to hole it in place. It's very neat and you would have to take the upper cowling (where the windshield wipers go on) off to see it. You only cut a hole big enough to remove the wire connector and then put the 1 1/16 socket through to remove the sensor. You're not cutting a hole big enough to remove the motor.
2nd...my manifold gaskets are fine, they don't need replacing.
3rd....I guess you would never cut your radio bezel to install a double din either.
I should of replaced my gaskets. But then again when the problem 1st happen I took it to the stealership and they replace them for me but I passed on the sender. So hopefully my gaskets are ok for a 11 yr car too. But really how do you know if they replaced the gaskets unless you was there watching them. That's the million dollar question.
4th...I was merely stating what I would and would not do to MY car to replace the OPS. You can cut, glue, tape or whatever else you want on your car. I don't care!
