I would think the most common would be oil pump failure, timing chain ,
valve spring breakage, missed shifts,wrong gear over rev's. Last but not least, water sucked into CAI.
I just busted the valve spring in cylinder 1 last week. Luckily it happened while I had the car idling in my driveway so no catastrophic failure or permanent damage. It did however cost me an upgraded cam kit from the fine gentlemen of EnglandGreen
I've been here for a few years and never seen anyone post anything about a destroyed engine. Not an LS1/6 at least. However there have been posts with members reporting very high mileage engines and still going strong. All depends on the maintenance.
-Alex
What he said. While it's not a perfect motor, I heard mechanic after mechanic talk about how bullet proof these engines are to going Kaboom. Nah not so for all my Wankel RX8 friends.
I've been here since 02 and I can't say I remember any posts of a major implosion of an LS1/LS6 (although Matt just changed that!). dgrant's 300 mile+ engine has to be an example to all although I think it's needed a new head gasket.
Well then mark that down as a stroke of great luck!!!!!!!!
-Alex
This is what i'm thinking. the only thing that would really be catastrophic would be a timing chain failure, which is highly unlikely on a close to stock engine under 250k miles. i love how bullet proof these engines are! This is why i ask this question, because i don't recall hearing about any catastrophic engine failure on an LS engine. You could probably just keep it running forever with regular maintenance!
