C5 Dead battery/locked out
Old Jan 6, 2011 | 02:22 PM
Caesar68's Avatar
Caesar68
This happened to me. You are sticking the key too far in. Try it about 3/4 of the way in
Old Jan 6, 2011 | 02:34 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Hmm, just tried mine. Turned key counter-clockwise and the door unlocked.
Old Jan 6, 2011 | 04:00 PM
ffas23's Avatar
ffas23
Originally Posted by 8VETTE7
2000 and newer C5's only have a keyhole in the drivers side door.
Didn't know that I own a '99. Learn something everyday.
Old Jan 6, 2011 | 04:11 PM
02z06dave's Avatar
02z06dave
are you turning the key the right way
Old Jan 6, 2011 | 08:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try SYNCING the FOB. Press LOCK & UNLOCK both at the same time and hold them until the horn toots. (may take a min or so to sync) Then see if it will unlock with the FOB.
BC
Old Jan 6, 2011 | 08:59 PM
Jet-Jock's Avatar
Jet-Jock
Originally Posted by Gitusum
I am betting the door lock has been changed at some point or the ignition has
Old Jan 6, 2011 | 09:02 PM
Jet-Jock's Avatar
Jet-Jock
And the door handle is the same used on many GM models. Makes you feel real good about that near 50K Corvette sitting at a traffic light and that Bonneville next to you has the same door handles!
Old Jan 8, 2011 | 06:29 PM
surges14's Avatar
surges14
Cruising
i ended up opening the door with a wire hanger it took a lot of time that was my solution (no i didn't damage the window or the seal thank god i washed it right after)
nope ive been the owner since new
Good point. Direction you turn the key to unlock would make a difference. Just tried all of my keys and it takes next to no effort to turn the key and lock or unlock the car...
i turned it both ways made no difference
since i opened it i haven't tried the key again ill let you know how it goes form here on
Old Jan 10, 2011 | 02:03 AM
striper's Avatar
striper
or an Oldsmobile, too!
Old Jan 10, 2011 | 04:43 AM
ffas23's Avatar
ffas23
That doesn't surprise me none its been that way with GM sharing parts with all their brands for as long as I can remember and I have been around GM vehicles for a very long time since the 1960's. Trust me they shared way before that time period also.
Old Apr 8, 2015 | 10:51 AM
skyvue's Avatar
skyvue
Currently having this same problem and can't get into my car. Neither key or FOB works even though the keys both physically turn in both directions. It still does not unlock the door. Not sure I have any other options besides calling a locksmith?
Old Apr 8, 2015 | 01:31 PM
dbgoodwin's Avatar
dbgoodwin
This thread makes me want to go check to make sure my key unlocks the door.. gotten so spoiled with key fobs that I haven't even thought to check.
