Hello.my oil sending unit went out weds. morning,today the service engine light came on,i'm assuming the oil sender being out could cause the light to come on but am asking for anyone else's opinion with this matter.Any input will be appreciated.Thanks,Karey
Same thing happened to me. But the check engine light may not part of the OPS problem. So you need to check codes from the DIC, and find out what's going on.
U1096 Loss of Communications with IPC but I did not see this under TCS in my codes list. There is a U1016 under my list but it's still a loss of communications with PCM.
Theres a video on you tube listed under C5 Oil sender,shows fixing by going behind manifold with an extension and socket.I haven't looked on my car yet but if that video is right and accurate it don't look real hard to replace.Any input on this would be great.Thanks to everyone for all the help,this forum is so cool and very informative also,Thanks again,Karey
