active handling/abs
Old Jan 9, 2011 | 03:37 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Default active handling/abs
Just started troubleshooting my ABS/active handling problem on my C5. Ran the codes; and there were alot of them; mostly history and shouldn't have to do with my problem. 3 of them could be related to my issue; C1287H steering position sensor circuit, C1214C&H solenoid valve relay contact or coil circuit open, and C1225H wheel speed sensor circuit. The C1214 code will not reset. Shouldn't the wheel sensor code tell me which one of the wheels is causing the problem? Also, is the other 2; steering position sensor and solenoid valve relay something I can take care of myself? Where do I look for them? Any assistance would be appreciated.
Old Jan 9, 2011 | 05:31 PM
dougbfresh's Avatar
dougbfresh
1214 is a relay inside the EBCM-time for a rebuild of the unit. www.absfixer.com.
