Power antenna install
Old Jan 11, 2011 | 06:20 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default Power antenna install
Are the necessary power wires already in place to install a power antenna in a '99 FRC?
Old Jan 11, 2011 | 07:34 AM
dougbfresh's Avatar
dougbfresh
Running the power lead from the radio/reciever to the antenna.
Old Jan 11, 2011 | 10:47 AM
fastvett's Avatar
fastvett
Old Jan 11, 2011 | 10:53 AM
DeeGee's Avatar
DeeGee
There are two separate wiring diagrams for the Convertible and the Coupe/FRC in the manual. They show a specific wire from the radio to the power antenna in the Vert which is not shown for the coupe. Not certain but my guess is no; not in a coupe
It'd be easy enough to run one though. Take it from the switched power supply and it will only extend when the ignition is on. Better still, add a switch in the line and you can select up or down as you see fit. The Vert antenna grounds on the rear frame.
Old Jan 11, 2011 | 11:04 AM
99DOCFRC's Avatar
99DOCFRC
Here is a write up from the forum on a Z06 power antenna install.
https://www.corvetteforum.com/c5/use...na-install.php
To Power antenna install
