[Z06] Z06 Lifting Question
Old Jan 11, 2011 | 09:17 PM
rjayorr's Avatar
rjayorr
Default Z06 Lifting Question
Hello All,
So for us regular guys that can't afford floor lifts in our garages yet, I need some advice from you on lifting my Z and supporting it with jack stands. The Owner's manual shows me where to lift it - which is dang near impossible on the front, but I finally did get it in the air. Have any of you successfully used other spots to lift and support it, or do I get to monkey it with two jacks every time I want to get all 4 wheels off the ground?
Any advice would be greatly appreciated.
Thank you,
Robert
Old Jan 11, 2011 | 09:33 PM
wallifishrmn's Avatar
wallifishrmn
You can make a set of ramps and use wood to lift your Z06 for under $20. You also need a floor jack and 4 jack stands. I have mine jacked up now and lift it all the time using this system---cheap & simple. See this website:
www.Z06vette.com/diy_lift.php
Old Jan 11, 2011 | 09:34 PM
71corv's Avatar
71corv
St. Jude Donor '08
As my Z06 is lowered, I drive onto 2x10's front and back. Use two jacks to raise the front and the rear. Takes a little time, but it's the only way I have to raise the car. Have the frame savers on each side that have the jacking pads on them.
Gene
Old Jan 11, 2011 | 11:05 PM
rjayorr's Avatar
rjayorr
Thanks for the quick replies guys. Since mine will be lowered very soon, I like the wooden block idea.
Thanks again,
Robert
Old Jan 11, 2011 | 11:18 PM
tlc0706's Avatar
tlc0706
I use almost the same system as wallifishrmn. Made 4 short ramps w/2x12's--front 2 are slightly longer than the back--They each are stacked--shorter pieces on top......If you like will measure pieces tomorrow...heavy as heck but, they work to easily get the jack w/2x6's under the cross members..
Tom
Old Jan 12, 2011 | 06:49 AM
firefighter813x's Avatar
firefighter813x
I use my harbor freight motorcycle lift to raise the rear and then use my regular floor jack with a bunch of rags to lift the sides of the car right before the rear wheels.
Old Jan 12, 2011 | 07:34 AM
Must_Have_Z's Avatar
Must_Have_Z
I got Race Ramps to raise the front of my lowered Z, and a low-profile Harbor Freight jack raises the rear under the cross-member. I also have rocker rails so when I just need to lift a corner (cleaning wheels, etc.), I simply jack right under the rocker rail. Race Ramps are a bit expensive, but worth every penny!
Old Jan 12, 2011 | 07:53 AM
Paul 75 L82's Avatar
Paul 75 L82
If you use ramps, (and I do), go to Target and buy 2 cheap door mats. They are probably about 20" x 30". Put the mats half under the ramps and the other half sticking out so when you drive over the mats and onto the ramps the ramps bit into the mats and it keeps them from sliding. works great. With that being said now I just use a lifting lug and my floor jack and just jack it up and then slid in the ramps. I also built 2" x 8" blocks that are about 2 feet long and about 6 board thick when I want to raise the complete car.
Old Jan 12, 2011 | 08:11 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I use Race Ramps, and jack stands...
Get a couple low profile jacks too. You will need them ... trust me.
Harbor Frieght has some decent ones for $60 (see my 2x blue ones on the left of my pic).
Old Jan 12, 2011 | 11:38 AM
Paul 75 L82
Toque, that's a great picture. For all of the guys that aren't experienced with jacking a C5 that picture is a good guide. You have a gook looking garage. Looks like your Z is happy.
Old Jan 12, 2011 | 11:50 AM
Toque's Avatar
Toque
Thanks Paul !
It sure feels a LOT safer under there on ramps. I used to work under it with just jack stands. I always felt uneasy to say the least !
Don't forget the wheel chokes when being on a ramp... . Mine are Orange in the picture.
My garage is my favorite place to be on the weekends. Other than driving it of course...
Toque
Old Jan 12, 2011 | 02:09 PM
Badd LS6's Avatar
Badd LS6
if you want to jack from the frame on the sides MAKE SURE to get jacking pucks..and make sure your local chevy dealership knows about these pucks also or this will happen
Old Jan 12, 2011 | 04:18 PM
Paul 75 L82
That's terrible, I have always thought that the pucks should have been made into the car permanently.
Old Jan 12, 2011 | 06:54 PM
rjayorr's Avatar
rjayorr
That sucks, sorry to see that man. I remember seeing those holes on the bottom sides of the chassis, I assumed they were there for production purposes only. Is it GM that sells the pucks?
Thanks for all the great feedback!
Robert
Old Jan 12, 2011 | 08:11 PM
tlc0706's Avatar
tlc0706
Robert
A good number of forum sponsors sell the pucks........
Old Jan 12, 2011 | 08:30 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
They use to, that jack is $160 now but Northern has some on sale for $99 reg $199
Old Jan 12, 2011 | 09:09 PM
Toque's Avatar
Toque
Try Product # 67408 at Harbor Freight site. Its $79.99 online, but the flyer that I got in the mail its $59.99... (Price good till 1/27/11)
Its on the front cover of the flyer.
You can get a flyer at the store entrance...
Toque
To Z06 Lifting Question
Old Jan 12, 2011 | 09:14 PM
BPG's Avatar
BPG
if you guys would have seen the contraption of wood and jacks and jackstands i had to use to get my driver side header in... you would have ALL taken a life insurance policy out on me .
good info, guys
Old Jan 12, 2011 | 09:36 PM
Paul 75 L82
We've all been there. I remember what I had to do to get the catback off without a lift.
Old Jan 12, 2011 | 10:54 PM
ILM-Express's Avatar
ILM-Express
MFIC
I use this 99 dollar jack from Costco
