need help
Old Jan 13, 2011 | 02:27 AM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
Default need help
Umm i was looking at my vehicle history thanks to sponge vette and came up to this LS1 MM6 - 6-SPEED MANUAL TRANSMISSION and MN6 - 6-SPEED MANUAL TRANSMISSION. what the different between the two? here my history if it helps.
VEHICLE BUILD
Merchandising Model : 1YY37 -2000 CORVETTE HARDTOP
Gross Vehicle Weight Rating : 1637 kg (3610 lb) Order Number : BZTW2R
Build Date : 12/23/1999
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AR9 BGR
B34 - COLOR-KEYED FRONT FLOOR MATS -CARPETED B84 - BODY SIDE MOLDINGS
C60 - AIR CONDITIONING DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS FE3 - SPORT SUSPENSION
FE9 - FEDERAL EMISSIONS GU6 - REAR AXLE 3.42 RATIO
IP3 - TRIM INTERIOR DESIGN - AR9 JL4
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63
MN6 - 6-SPEED MANUAL TRANSMISSION NF2 - FEDERAL EMISSION SYSTEM
NK4 - LEATHER WRAPPED STEERING WHEEL QD4
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UZ6 U52 - ELECTRONIC INSTRUMENTATION
U73 - FIXED MAST ANTENNA VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG
YGH 1SA - OPTION PACKAGE 01
19I - INT EBONY INTERIOR TRIM 193
70U - TORCH RED
Thanks, Chris
Old Jan 13, 2011 | 03:07 AM
DeeGee's Avatar
DeeGee
I think this input from BlackZ06 should help:
Originally Posted by BlackZ06
I believe the separation, in more detail, is that ....
MM6=Borg Warner T56 Transmission
M12 = Borg Warner T56 Transmission (Z06 ratios)
MN6=code for manual transmission vehicle
ALL Manual C5 Corvettes come down the production line with code MN6, as that tells the factory to install clutch pedal, console for a manual shift, wiring harness, whatever ..... and coupe's and convertibles have code MM6 for their transmission, the Z06 has code M12 for its transmission.
The MX0 code for the automatics puts a different console and shift set-up in the car, a different brake pedal and no clutch or clutch hydraulics installed, etc. The MX0 and MN6 codes may apply to changes to the PCM software, radiator installation of a an auto trans cooler and line ... it is not just "cabin" items that can be tied to the installation codes.
Old Jan 13, 2011 | 12:47 PM
chrisk92's Avatar
chrisk92
Thank that help now i understand it
To need help
