C5 Build Sheet
Old Jan 13, 2011 | 10:44 AM
don hall's Avatar
don hall
Default C5 Build Sheet
According to the info listed on SECRETS OF THE C5, the build sheet is located in the front re-bar.
Did a search for 'build sheet' & 're-bar' in the C5 section, but no luck.
Anyone familiar with the term 'rebar', and its' location?
Thanks,
don
Old Jan 13, 2011 | 10:46 AM
dougbfresh's Avatar
dougbfresh
The front frame rail is what they are referring to, you have to take the bumper off to get to it.
Old Jan 13, 2011 | 10:52 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Why bother when you can order a clean unwrinkled version from the Corvette Museum - click here!
Old Jan 13, 2011 | 10:53 AM
don hall's Avatar
don hall
I thank you ....
There must be a reason, but if my sheet is still there, it will remain there.
Old Jan 13, 2011 | 10:54 AM
don hall's Avatar
don hall
Got it! ...... and Thanks.
Old Jan 13, 2011 | 11:03 AM
dougbfresh's Avatar
dougbfresh
Build sheet is kind of worthless anyway.
Old Jan 13, 2011 | 11:12 AM
don hall's Avatar
don hall
Default build sheet
..... the window sticker provides the data.
Old Jan 13, 2011 | 11:23 AM
dougbfresh's Avatar
dougbfresh
Actually more. The RPO codes in the glove box are also more useful.
Old Jan 13, 2011 | 12:18 PM
GeneT's Avatar
GeneT
Do you have to order the build sheet to be able to order the window sticker from the NCM ?? I've heard both yes and no.
Old Jan 13, 2011 | 12:29 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
According to he NCM web site they only say that if you order a reproduction window sticker you must also order the build sheet. It appears that you can order the build sheet only.
If you are a member they are $30 and $40 for non-members plus $5 to have it laminated.
I ordered both laminated. I also have the original window sticker and I plan on getting the original bulid sheet out of the front bumper one of these days.
Old Jan 13, 2011 | 12:32 PM
GeneT's Avatar
GeneT
That's the way I read it too. I only want the Window Sticker, not the Build Sheet.
Old Jan 13, 2011 | 12:40 PM
NittanyLionDen's Avatar
NittanyLionDen
What kind of condition would the original build sheet be in if you retrieved it from the bumper? Anybody done this?
Old Jan 13, 2011 | 12:56 PM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
Thanks for that link I just ordered the build sheet and the window sticker for my 02 convertible!
Old Jan 13, 2011 | 01:01 PM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
I just got off the phone with the NCM and they told me I must order both and could not order the window sticker alone. Go figure...
Old Jan 13, 2011 | 01:12 PM
GeneT's Avatar
GeneT
Bummer, that's $40 plus another $40 (non-member) for something I don't want.
I think I'll pass.
Thanks for checking, I was going to call them too.
Old Jan 13, 2011 | 01:14 PM
realvc's Avatar
realvc
I like having the build sheet and the window sticker. I got the lamenated ones. The original window sticker was folded up in the owners manual. There are some on this forum that have taken the build sheet out of the frame rail when they had the bumper off for repairs or painting. Most of the time they are in better shape than the ones that used to be placed over the gas tank like on the older vettes.
Old Jan 13, 2011 | 02:12 PM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
I think I'll pass.
Hey GeneT; we've got exactly the same car: 02 MY vert!
To C5 Build Sheet
Old Jan 13, 2011 | 03:07 PM
PostShawn's Avatar
PostShawn
Just for the OP's knowledge for next time here is where it's located:
Old Jan 13, 2011 | 03:10 PM
It's part of the frame - there is a hollow tube right behind the front fascia that goes width wise across the car. The build sheet should be stuffed inside that. At least that is where mine was. You will have to take the front fascia off to get to it.
Old Jan 13, 2011 | 03:18 PM
don hall's Avatar
don hall
Great photo..... the condition of that build sheet is far superior to the one I extricated from the frame rail in the engine compartment of my '93...... completely shredded.
There must be a reason for secreting that document ..... anyone know the reason?
