400/400
Jan 18, 2011 | 08:37 PM
400/400
Well, here we go. The car is going into the shop next Monday. 99 A4, 315 gears, lg street headers, vararam, 42 lb injectors, torquer 2 232/234 112 lsa, 5.3 ported heads from tsp, and a 3200 stall. Can I make it?
Jan 18, 2011 | 08:38 PM
yes
Jan 18, 2011 | 09:44 PM
Quote:
Originally Posted by
Gitusum
yes
Jan 18, 2011 | 09:52 PM
Should certainly be within reach. Good luck.
Jan 19, 2011 | 08:04 PM
Jan 19, 2011 | 08:10 PM
380-400rwhp.....my guess.
I laid down 296rwhp stock, and installed the LG's streets and LS6 manifold, Vararam and Power duct, tune.....never got around to another dyno pull cause the guy went on vacation before they finished the installs. BUT it's a different beast now! WAYYYYY faster!
Jan 19, 2011 | 08:32 PM
sure hoping for more than that. that sounds like cam only #'s. I will also be adding stage 2.5 5.3 heads.
Jan 19, 2011 | 08:46 PM
kjmj
sure hoping for more than that. that sounds like cam only #'s . I will also be adding stage 2.5 5.3 heads.
Not with an A4
You should make it easy. I was a little over that with a smaller cam
Jan 19, 2011 | 09:01 PM
my tuner is expecting 100 rwhp gain from this combo. currently @ 336 rwhp and 342 rwtq. said the stall is going to make it feel like more in the butt-o-meter.
Jan 19, 2011 | 09:05 PM
i had the same setup except i had a ud pulley and a fast 90 3.42 gears and i made 439rwhp and like 389tq
Jan 19, 2011 | 09:21 PM
Gitusum
sounds like the tsp 2.5 5.3 heads worked pretty good for you. have you been to the track yet? what kind of traction issues do you have on the street?
Jan 19, 2011 | 10:29 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Should not be an issue
Thanks,Matt
Jan 20, 2011 | 01:19 AM
St. Jude Donor '10-'12, '25
Sounds awesome!
