[Z06] rebuilding trans soon, what else?
I have been trying to gather info on this, but I'm still not sure what I should do. I have a couple lingering questions, for those of you with more knowledge than me:
About the transmission rebuild:
There are lots of upgrades available, but are there any that are more worthwhile than others? I've read that the upgraded main shaft is a good idea, but I don't know why. If anyone could fill me in on this, I would appreciate it.
About the clutch:
I will NOT start another "which clutch should I get" thread..... Although, since you're already reading this, which clutch should I get?
The car will make a max of about 460 rwhp when I get around the the H/C swap, and it's a daily driver. Stock-like engagement would be ideal, since I do get stuck in traffic from time to time. From what I recall reading, there is ONE clutch that has smooth engagement, no noise, and great holding power... I also remember it was about 2x as much as other options. Anyone know which one I'm talking about?About the flywheel:
Aluminum? I've had one on my old 911, and it made traffic a total PITA; however, I know this car is a completely different beast. The surplus of low-end torque should make that less of an issue. I really don't like the chatter though. Is it possible to get a clutch/flywheel combo that doesn't make all that noise? (in the perfect world, there would be a forum member somewhere nearby who would be kind enough to let me drive their car if they have a clutch/ aluminum flywheel combo they enjoyed).
Finally: Is there anything else I should be considering while I'm doing all of this? New slave? Should I replace any other parts while I'm doing all this?
I know this is a lengthy post, but I'm figuring that this will probably be another 3-4k dropped into my baby, so I want to make sure I do it right. You guys set me straight when I was doing my header purchase/install, so I'm turning to you again.
Thanks in advance for any advice!
-John
It's really easy to get to with the drivetrain out.
Definately get new hydralics, perhaps also a remote bleeder from Tick Performance. It will make fluid flushes a snap.
Also maybe an Elite Engineering tunnel plate with heat shielding?
New flywheel and pressure plate bolts are necessary. Go ARP and don't worry about it.
Get a shop manual if you don't already have one. Just the torque specs and sequences make it invaluable.
And since you'll have the shifter out, may as well dump the stock piece of crap if you haven't already.
If your O2 sensors are even close to being changed, just change them while they're out anyway. They about $80 a piece or so.
How about a thicker/insulated tunnel plate?
Please keep the suggestions coming. All input is greatly appreciated.
