brake pedel deadzone
Old Jan 22, 2011 | 01:48 AM
99alvette's Avatar
99alvette
Default brake pedel deadzone
My brake pedel does not feel right it goes a good 1/4 to 1/2 to the floor with no resistance and before anything happens is that normal?? I have brake flud its below the max mark but not empty by any means whats wrong? Fresh rotors and pads didn't fix the issue.
Old Jan 22, 2011 | 08:53 AM
99alvette's Avatar
99alvette
ttt
Old Jan 22, 2011 | 10:42 AM
y2krtaf's Avatar
y2krtaf
I would try bleeding the system.If bleeding the system doesn't cure it,you may have a master cylinder going out.
keep it simple though and try the easy/cheap fixes first.
Good luck.
Old Jan 22, 2011 | 12:29 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
Good luck.
second vote for bleeding the brakes
Old Jan 22, 2011 | 12:31 PM
99alvette's Avatar
99alvette
Know this might sound dumb but how do you bleed the brakes?
To brake pedel deadzone
