Battery
Old Jan 22, 2011 | 04:21 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Default Battery
well it happened the battery is dead, haven't started the vert in over 3 weeks, the temps are fridgid ,so i went to start it and its dead, should i just let it be until summer, or should i try to jump it
Old Jan 22, 2011 | 04:30 PM
jrose7004's Avatar
jrose7004
I'd put a battery charger on it and build it up and try and start it.
Old Jan 22, 2011 | 04:32 PM
Phanni's Avatar
Phanni
There's no reason you can't jump it. However if you have the time a charger works too.
Old Jan 22, 2011 | 04:34 PM
Chuck A's Avatar
Chuck A
But the question can i harm anything by not starting it?
Old Jan 22, 2011 | 05:17 PM
Chuck A's Avatar
Chuck A
The battery is less than 2 years old
Old Jan 22, 2011 | 05:21 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You might be able to save the battery, I would get a Slow charger and let it go over night, It might just bring it back to life, If not new battery time and you should have a tender anyway seeing your car sits, I like the CTEK US3300.
Mr.Bill
Old Jan 22, 2011 | 05:24 PM
Chuck A's Avatar
Chuck A
Mr.Bill
I bought the battery from Auto Zone,and i get a % of money for certain amount of years owned, yea it was all my fault, but working so much i forgot to start her up, and the temps here have been colder than usual
Old Jan 22, 2011 | 05:31 PM
romeospete's Avatar
romeospete
Remove the battery and put it on a slow charger. Don't put it back in until spring when you get the car out. You are doing more harm than good just starting it every few weeks. Don't start it unless you plan on driving it. My vette sits in the garage all winter and I remove the battery and store it in the basement.
Old Jan 22, 2011 | 05:33 PM
Chuck A's Avatar
Chuck A
so i should take the battery out, iam thinking maybe i should bring it back to Auto Zone get it recharged and wait until spring to put it back in, would that be correct?
Old Jan 22, 2011 | 05:36 PM
romeospete's Avatar
romeospete
Yes, I would get it recharged somehow. Don't store a dead battery.
Old Jan 22, 2011 | 05:41 PM
Chuck A's Avatar
Chuck A
i guess i will need to take the battery out do you think i will need to reprogram the FOB, and everything else?
Old Jan 22, 2011 | 05:47 PM
atmsrus1's Avatar
atmsrus1
Mine did that last week and I just jumped it off and drove it around awhile and all was good.
Old Jan 22, 2011 | 05:49 PM
Chuck A's Avatar
Chuck A
Thats what i rather do, instead of taking it out, maybe i will just disconnect it, and the jump it in the spring, and then see what happens
Old Jan 22, 2011 | 05:56 PM
hfddirty30's Avatar
hfddirty30
Pick up a low amp charger and restore the battery to a full charge.Also DO NOT store the battery on concrete put on a block of wood or anything to keep it off concrete.Autozone will charge the battery for free, but will not replace it because at is discharged.Only if it will not hold a charge.
Good Luck,
Ed
romeospete's Avatar
romeospete
Yes, you will, but it is pretty simple to do.
Old Jan 22, 2011 | 05:59 PM
Chuck A's Avatar
Chuck A
Originally Posted by hfddirty30
:iagree
Good Luck,
Ed
yea after amount of years they wont replace , but they will lower the price for a newer one, so i will take it to Autozone have them charge it then store it on a wooden floor or area and then put it back in , in the spring time, i guess i will need to know how to reprogram the FOB
Old Jan 22, 2011 | 06:04 PM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
I was in the same situation. forgot to start up the car been busy. i ended jumping my car. evrything went fine look like their no problem yet but i still would recommended myself to get a battery charger
To Battery
Old Jan 22, 2011 | 06:08 PM
romeospete's Avatar
romeospete
Turn on ignition, but don't start engine. Press options button repeatedly until you come to a blank screen, then press and hold 'Reset' until you see 'FOB TRAINING' press 'Reset' again and it will ask you to hold lock and unlock at the same time and it will beep when complete. Then on to second fob.
Old Jan 22, 2011 | 06:09 PM
Chuck A's Avatar
Chuck A
how long can i let it go without starting, thats the question i need to know, i rather not remove the battery , but i also do not want damage either
Old Jan 22, 2011 | 06:10 PM
Chuck A's Avatar
Chuck A
