Hvac
Old Jan 28, 2011 | 05:43 PM
corvettedaddy11's Avatar
corvettedaddy11
Default Hvac
No air is coming out of the vents when on low or high.Checked fuses all are good. Whats the problem?
Old Jan 28, 2011 | 06:12 PM
Vette C5's Avatar
Vette C5
Give us more details to help out.
Here any unusual sounds when you turn it to high?
Old Jan 28, 2011 | 06:19 PM
corvettedaddy11
No sounds or nothing !
Old Jan 28, 2011 | 07:22 PM
ALLEGRO's Avatar
ALLEGRO
What about on the medium settings?
Old Jan 28, 2011 | 09:22 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Dual Electronic HVAC control or manual control?
Old Jan 28, 2011 | 10:59 PM
corvettedaddy11
Dual controls, and no air low, med ,or high!
Old Jan 28, 2011 | 11:19 PM
dgrant3830's Avatar
dgrant3830
Check the connector on the fan motor itself and insure it's still plugged in. You are sure you check the correct fuse for it? The fan motor might have failed but it'll be the first time I've heard of that. Any Mice in the area where it's parked? We've heard many times of them critters getting in there and building a nest and for unknown reasons, they love the fan motor.
Old Jan 28, 2011 | 11:39 PM
corvettedaddy11
No critters, I checked fuse # 18 and 27 they are hvac fuses. Does anyone know what pin in the plug goes to the blower motor maybe I can OHM it out ?
Old Jan 29, 2011 | 09:54 AM
dgrant3830's Avatar
dgrant3830
Without looking at it this second, I would imagine there are only two wires to the blower motor...plus and minus 12 volts. There has to be a resistor network which I don't know where it is, that the controller selects the right voltage to the motor. I would suggest you pull the motor's connector and check for 12vdc there when its supposed to be on. Then if you have it but the motor isn't running, ohm the motor itself. If no vdc there when it should be, back up the diagnosis. Bill Curlee might have the schematic or maybe Lucky if he see's this thread.
Old Jan 29, 2011 | 10:07 AM
corvettedaddy11
THANKS dgrant3830
To Hvac
