Is there a way to check the tire pressure sensors out of the wheel?
I read a previous post,but I did see how is done.
I'm buying use ones and want to see if they are in working condition before i install them
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
I am not sure how you can test them outside tire. The TPM need to be enclosed to get a pressure reading. One way maybe to use a jar and sealable lid with the TPM attached to the lid, then put some air into the jar using a hand pump.
Not an expert on this, but not sure I'd want to pressurize a jar enough to find out if a TPS sensor functions. Maybe behind sandbags.
I've seen a couple of examples where people have installed them in PVC pipe with end caps to fake out the monitoring system into seeing the spare sensor. I would think that movement is the only requirement to wake them up, not rotation, since most sensors mounted in spare tires aren't going to rotate.
Easy answer - initiate the TPMS retrain in the car, then use a magnet with the TPMS in your hand maybe 15 feet from your car. No air pressure needed. I had a more complicated problem with TPMS testing that proves this will work:
I have a set of 4 unmounted TPMS and 2 fobs from a 2000 C5 that I just tested at Oreilly (for free), since my 2002 C5 will not communicate with pre-01 devices. They have a keyfob tester at the counter with a green activity light. It needs to be 3 inches from the transmitting device, which would make testing a mounted TPMS difficult.
All C5 fobs and TPMS transmit on the same frequency (315 Mhz). I brought a magnet along to Oreilly with my TPMS and fobs to test. I activated their tester, then held the magnet next to the stem as if I was doing a TPMS retrain for the car. About 5 or so seconds later the Oreilly indicator flashed to say it's alive. Worked great for me. This test will let you check any magnet-activated TPMS or keyfobs without unbundling a cozy C5 from its winter nap.
The free Oreilly test doesn't check range or pressure accuracy, but it does check life. There are a number of TPMS tools available which will do all of the above for $300+.
Used Sensors? Do you have an idea how old they are?
Battery life could be on it's way out....... Just a thought !
They are three years old but new in box. i think the batteries last 12 years or so.
I'm sure the sensors in my car now are originals,that would make the 12 going on 13 years
Originally Posted by DeeGee
The TPS is dormant until the wheel rotates so you'll only get indications that the sensor has programmed.
If you run the learn program, you can see if it will program to your car while the sensors are not mounted on a wheel, but you won't know if they will read the pressure until you mount them on a wheel with a tire and drive the car above approximately 15 mph so the pressure will read.
The car has a set in the wheels now. I want to check out a set that I obtain to see if they come alive.
Some said O'rielly has a tester,but there are no O'rielly in my area only Auto Zone and Advanceautoparts. I called them ,but there weren't any body there that knew what i was talking about.
The Oreilly tester was part of a key fob (remote door unlocker) battery test & replacement display on the front counter. They sell the various replacement coin cell batteries for your key fob. I just called both Autozone and Advance and they don't have one, sorry.
Todd
Todd after reading your pm,i was able to understand this post.
I wished we had Oreilly here,I've lived in Minn, in Pine City and I'm familiarize with them. I'll try the test,the way you explained it on your pm tomorrow.
Todd
Tested the TPMS as you advised. It worked. However I have one bad one. Do I need to do the same to reprogram the ones on the wheel back into the system?
Sorry for the late reply, and glad to hear it worked for you.
Yes, repeat the retraining for the TPMS in the tires. Just hold the magnet near the rim where the valve stem is. The last 4 you train will be reported and monitored on the DIC, and the former ones forgotten.
