Getting more UMMPPHH
Old Feb 4, 2011 | 04:17 AM
Bullet Proof's Avatar
Bullet Proof
100 hp shot of nitrous should do the trick
Old Feb 4, 2011 | 04:43 AM
mel3535's Avatar
mel3535
That GTO most have had some decent mods. I think they weigh over 4000 pounds, you car should be around 700 pounds lighter.
CAI,Headers,Exhaust,Tune.
Buy headers used for $700/800
Exhaust Used for $400-800 depending on what you get
CAI for $300
Tune for $500
Should get you around 350rwhp if you are a M6, 330rwhp if you are a A4.
And oh yeah IBTL
Old Feb 4, 2011 | 04:59 AM
sablan'01's Avatar
sablan'01
St. Jude Donor '12-'13
Old Feb 4, 2011 | 06:10 AM
red oneee's Avatar
red oneee
i guess the mods are seeping, since they closed the "vette with girls" thread
Old Feb 4, 2011 | 09:13 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by sfc rick
Jeeezuusss The guy just wanted to know how to handle a GTO, TELL'em !
Vararam Intake and Power duct, Z06 manifold, Longtube Headers/X-Pipe, and a tune....that'll make his eyeballs pop out next time.
Good lord at least someone answered the question without a stupid smartass answer (Smartass is better than a dumbass just so you don't know )
With these said mods to your Vette you should be able to put down 350+ RWHP to the ground and pull a similarly modded GTO (they are much heavier) -
and a used C5 Z06 (LS6 manifold) can easily be had in the Parts section for $300.
You could also add to the list:
(1) MSD Wires
(2) NGK TR55 Plugs gapped at 55
(3) Ported and Polished Throttle Body
The tune is the critical part, once all is bolted on then the 'DYNO' Tune will come and make all the parts flow together (maximize the combo)!
Now once you are ready to move up in power, I suggest going to Forced Induction as another BOLT ON option (yes it is truley a bolt on) -
Case in point - friends stock C5 Coupe with same mods listed above and 12 PSI of B@@ST and Meth injection makes 559 RWHP - Forced Induction done correctly will last a long time - again it is all in the tune!
Do Not spend enormous amounts of money, go to the Parts For Sale section here on the Forum and get the things you need for a 1/3 of the price
Thanks,Matt
Last edited by madmatt9471; Feb 4, 2011 at 09:15 AM. Reason: fix 250 RWHP to the correct 350 RWHP - sorry!
Old Feb 4, 2011 | 09:28 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
You want to keep them away from you, put on a Procharger it worked for me
Old Feb 4, 2011 | 09:40 AM
bontrager's Avatar
bontrager
Originally Posted by Aviator54
I have a stock 2000 C5 with 80K miles and was out cruising one sunny morning when a 2008 GTO pulled up along side and started showing off. Well, not to be outdone I gave him some show-off back. Mines red and his was yellow...so as the light turned green we slammed it and I pretty much had him thru third but then he just steadily pulled past me and there was nothing I could do. Talking about being humiliated!
So my question is, aside from the fact of never ever showing off in front of another GTO, how can I keep this from happening again? What engine mods can I do? Any and all help would be greatly appreciated.
Good post; a similar think happened to me also in a 2000 6 speed vert. I won't mention the car that seemed to accelerate past me ( OK, I will; an Audi a4 turbo) pretty sure his was an automatic and I did have a car in front of me. Needless to say he had a huge smile on his face; and a youngster to boot ( added salt to the wound).
Have added a cold intake system and will probably do an MagnaFlow crossover pipe, short shift kit and caggs, yet to be installed, maybe the new manifold that is mentioned above and a performance tune as soon as I can find someone to do it in Western, PA. Understand that from some members on this forum that a new cat back system won't raise horsepower just sound better????
Old Feb 5, 2011 | 12:44 AM
JustinStrife's Avatar
JustinStrife
Supercharger mod and you'll be playing with C6 Z06's. No bottles to fill, no bottle warmers needed, doesn't take up any room in the trunk, drives like stock, but is always there when you need it.
Old Feb 5, 2011 | 01:24 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Like most have said put on this add that try this change that spend 4-5k get 45-65 more rwhp or add a Supercharger and get 100-150 for 6500.00 My first motor I did all this just to get 390rwhp and I spent 4800.00 now I spend 250.00-350.00 to pass smog every 2 yrs now I have a motor all N/A Running 485rwhp and 465rwtq with long tubes next move before next smog date I will dump the LG'S and add a procharger gain another 150+ rwhp and use some shortys that have the carb sticker and be fine
Old Feb 5, 2011 | 03:55 AM
lil vette's Avatar
lil vette
150 N.I.T.R.O.U.S. can do yourself for $1000.00
Best bang for the buck
