While I was over at the detailers, we noticed these rough spots on the back deck of my 2002 coupe. He says it's a bad fiberglass job by GM. Does anybody know anything about this . It is most diffently under the paint.
The is a TSB on bubbling rear deck lids, search for it. Only fix is a new lid, some kind of insulation leached through the substrate and contaiminted the base material.
My guy said he can scrape out the bas spot fill with some type of Polycarbonite and repaint. Yes , No??
I've noticed this on my 2000 coupe, too. It's so subtle you can only see the textures if the car is clean and you are looking at it in a reflective light on the surface of the deck lid. I wasn't aware of the TSB until just reading this post - anyone know if it ever gets "worse" as in paint peeling off, or if it just stays the way it is now?
A few have tried to repair this only to have it return soon after.
If GM could have repaired this they would not have just replaced the deck lid in the field. GM's fix was a NEW decklid. Once whatever it is contaiminted the deck-you'd have to cut out the spot to really fix it, the problem starts on the backside.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Unfortunately most of us have it. If you look really hard, with a clean and polished car, you will see some irregularities. Sucks, but I guess we just have to deal with it.
