traction control system
Old Feb 7, 2011 | 04:39 PM
Tyteflows's Avatar
Tyteflows
Default traction control system
recently when im hitting about 80mph i noticed i have been losing power. i saw a traction control system enabled or some similar message on the DIC. i turned the traction control off and i was able to go past 80. you guys have any idea what the fix would be with this problem. its a 2004 coupe bone stock.
thanks fam
peace!
Old Feb 7, 2011 | 04:44 PM
02*C5's Avatar
02*C5
Am with ya because I have experienced the same thing. The car pulls the traction control flashes on the DIC I turn it off then no prob.
Old Feb 7, 2011 | 04:45 PM
ALLEGRO's Avatar
ALLEGRO
Check your codes. This will steer you to what you need to do.
Good luck
Old Feb 7, 2011 | 05:08 PM
dougbfresh's Avatar
dougbfresh
If you have mag. ride control, your shocks are most likely dying-the AH system limits you to 80mph when the shock become sick.
To traction control system
