Help with info
Old Feb 8, 2011 | 05:24 PM
01Z0Sixx's Avatar
01Z0Sixx
Default Help with info
I bought my 01 z a little over two years ago (Oct '08) in Portland OR, and due to my excitement of owning my first Vette, I lappsed in trying to get all the build info on the car from the owner via the dealer. (Gran Prix Imports) The car was in on consignment when I got it. 17xxx miles and a Shirl Dickey 418 LS2. I am trying to track down any info on this motor as far as components and specs. If this was a "cookie cutter" build or one-off custom. I don't know what shop did the work either. The car has 5 pt roll bar, upgraded clutch, stereo, exhaust, and other minor mods... If anyone one has an idea in the area of the previous owner or Shirl Dickey, I would appreciate it. Thanks in advance.
Old Feb 8, 2011 | 07:54 PM
zeevette's Avatar
zeevette
Are you sure it's not " Scoggin Dickey", and not Shirl? They're well known Corvette parts, etc. AKA, SDPC.
Old Feb 8, 2011 | 08:52 PM
01Z0Sixx's Avatar
01Z0Sixx
I'm pretty sure I remember Shirl Dickey. I only found a thread on LS1tech from '06 about another one and a 454. I'm hoping someone from the portland area will recogize the car and know the previous owner as the dealer wouldn't give me any info(obviously not expecting anything)... or the whereabouts of Shirl Dickey...
Old Feb 9, 2011 | 12:52 PM
01Z0Sixx's Avatar
01Z0Sixx
ttt
Old Feb 9, 2011 | 10:47 PM
01Z0Sixx's Avatar
01Z0Sixx
off to work. For the night crew...
Old Feb 10, 2011 | 02:54 PM
01Z0Sixx's Avatar
01Z0Sixx
Should I try this in another section? I guess I'll go try LS1tech and see what i find there.
Old Feb 10, 2011 | 03:08 PM
dougbfresh's Avatar
dougbfresh
http://www.ls1tech.com/forums/genera...r-rockers.html
Old Feb 10, 2011 | 03:42 PM
01Z0Sixx's Avatar
01Z0Sixx
Thats the one I found too. I found other various mention of it but no contact info. MrEracer is Shirl Dickey's screen name on here and LS1tech. He hasn't been on here in years and not on LS1tech in months. I'll just try sending him a msg on the other forum and see what happens. Thanks for the help though.
Old Feb 10, 2011 | 04:47 PM
dougbfresh's Avatar
dougbfresh
Looks like a one off to me.
Old Feb 12, 2011 | 07:29 AM
01Z0Sixx's Avatar
01Z0Sixx
Default Found build list...
I found my breakdown of motor finaly burried in a box, but my cam is in question. What cam... Wtih the cs=ustom length pushrods would this lead to be a custom grind? I am not very cam savy. My cam was just pulled and has damge on all lobes and my mechanic said there was only a number on it. he called comp and is awaiting the maker of the cam. I am trying to do research on my end to speed this up. any help appreciated.
info:
Shirl Dickey Race Engineering LS2 Short Block 418cid.
LS2 Aluminum Block.
Eagle LS1 Crank.
RPM Forged Rods.
Diamon Forged Pistons, Pins and Rings.
Clevite Rod and Main Bearings.
LS2 Timing Cover, Valley Cover, Timing Assembly & Cam Sensor.
ARP 12-point Head Stud Kit.
Racetronics LS2 Cam Sensor Adapter Harness.
DTE Differential Strut Brace.
Textralia OZ700 Clutch. 373 Geared Differential.
Wolfe Racecraft 5pt Roll Cage. 5pt Race Harness.
LS2 Fuel Rail.
Racetronic C5 Fuel System running at 63 psi.
SVO 30lb injectors.
Halltech Cold Air Intake.
LS2 90mm Intake Manifold.
LS2 90mm Throttle Body.
ASP Pulley.
LG Motorsport Pro Long Tube Headers.
LG Motorsport X-pipe.
Titanium Cat-Back Exhaust.
Harland Sharp Adjustable Roller Rocker Arms.
Custom Length Hardened Chromoly ball tip pushrods.
CompR Hydraulic Lifters.
Absolute Speed Stage 2.5 LS6 Heads.
Black Competition Motorsports 18x9.5 and 18x10.5 Wheels
Also the last dyno was around 480rwhp/480rwtq
Is there more here or would i need bigger injectors and then a tune?
What are 30lbs good for?
To Help with info
