Hawk hps brake pads
Old Feb 8, 2011 | 09:13 PM
mooney201's Avatar
mooney201
Default Hawk hps brake pads
After reading some of your comments on rotors, I ordered slotted ones. They have not arrived yet, but the hawk hps pads did.
How do you guys like these pads?
Old Feb 8, 2011 | 09:16 PM
4SFED Z's Avatar
4SFED Z
I love them. Make sure you follow break in instructions.
Old Feb 8, 2011 | 09:17 PM
Kale's Avatar
Kale
I like them, good bite, no squeeling. They hum on every car I've used them on though. Minor annoyance.
Old Feb 8, 2011 | 09:37 PM
Kevs50th's Avatar
Kevs50th
What are the break in instructions for the Hawk HPS pads?
Old Feb 8, 2011 | 09:42 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
burn them in from several speeds to 0 mph, 30 60 etc. I didn't get a chance to do all that as I had to drive home 40 miles with an untuned newly cammed car. after the tune I did do some braking stuff,,,,I like 'em just fine!
dbaker's Avatar
dbaker
I run HPS on all my cars....Z06,S2K and GST.
Click on the "Bed-In" link on the right.
http://www.hawkperformance.com/performance/hps.php
\db2
carolina
Old Feb 8, 2011 | 09:49 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I cant hear anything from mine....than again I cant hear a dang thing in my car!
1.After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
2.Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
3.DO NOT DRAG BRAKES!
4.Allow 15 minutes for brake system to cool down.
5.After step 4 your new pads are ready for use.
Old Feb 8, 2011 | 09:52 PM
Had them on my '00 - very good pads. When I need new pads on my '03, will go with the Hawks.
Old Feb 8, 2011 | 09:54 PM
Kevs50th's Avatar
Kevs50th
Thanks to all for the quick responses on the correct "Bed-In" procedure.
Old Feb 8, 2011 | 10:06 PM
Oldvetter's Avatar
Oldvetter
I have HAWK HPS pads, they are GREAT ! I also run drilled and slotted rotors.
Old Feb 8, 2011 | 11:22 PM
mooney201's Avatar
mooney201
Thanks for all your replies, and the break in procedures. For my application, TPS did not recommend the drilled rotors, just the slotted ones.
Old Feb 9, 2011 | 12:09 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
I've got HPS brake pads and just noticed a small squeak from them the other day.
Old Feb 9, 2011 | 06:01 AM
DeeGee's Avatar
DeeGee
Just drove them for the first time today after breaking them in
Big improvement over stock so far but my old pads were in really bad condition. Firm braking and silent. cant comment on dust levels yet
Old Feb 9, 2011 | 07:16 AM
Tigershark3's Avatar
Tigershark3
I've had the Hawk HP's for 3 years now along w/ Brembo drilled and slotted rotors and would use them again. Quiet, good braking performance but as far as the dust I clean them a lot - they do appear to have a fair amount of dust.
Old Feb 9, 2011 | 07:24 AM
Ultimate ride's Avatar
Ultimate ride
Mine don't dust as much as OEM.
Old Feb 9, 2011 | 08:27 AM
VET IT B's Avatar
VET IT B
Love mine. 4 years now and I re bed mine every spring.
Old Feb 9, 2011 | 10:18 AM
ChargedGN's Avatar
ChargedGN
Dito, changed the fronts to HPS's and the backs were still original and now there is more brake dust on the back wheels then fronts after a week or so of daily driving
Seems to stop a little better also
To Hawk hps brake pads
Old Feb 9, 2011 | 10:30 AM
mooney201's Avatar
mooney201
Looking at the pads in the box, I see that the front pads look robust, while the back pads look like they belong to a Honda Civic.
Old Feb 9, 2011 | 10:31 AM
Kale's Avatar
Kale
Front brakes are usually bigger than rear brakes...
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Used HPS pads on my car. Love them!
Installed in Apr 08, lasted to Jan 2011 on a daily driver with R1 Concepts D/S rotors.
