Please Help With Oil Filter Selection!
Old Feb 11, 2011 | 10:44 PM
arkus's Avatar
arkus
I agree to the post above . Just get an AC delco
Old Feb 11, 2011 | 11:11 PM
robert miller's Avatar
robert miller
Originally Posted by jrprich
Go with WIX filters......you can't go wrong
One of the best out on the market. delco is junk to the wix filter for the oil...
Old Feb 12, 2011 | 12:36 AM
The PF46 or PF 46E will work just fine. The 46E is the newer version of that filter.
Old Feb 12, 2011 | 12:43 AM
vetteman741's Avatar
vetteman741
From: Motorsports Capital of the World..Indianapolis Indiana
Originally Posted by chris308
mobil 1 oil, mobil 1 filter
Old Feb 12, 2011 | 01:17 AM
itzza427's Avatar
itzza427
Wix is the way to go,,,they also make the NAPA Gold !! Wix is used by many race team,,,and is a top choice for commercial fleet operators!!The shop owner that built my sharks big block gave me the info on them. They build lots of race motors as well race themselves,,and know their stuff!! Good enough for me,,,Wix filters in ALL my vehicles!!
Old Feb 12, 2011 | 02:38 AM
Cheech Wizard's Avatar
Cheech Wizard
The Mobil 1 filter is identical to the K&N filter, except the Mobil 1 doesn't have the nut welded to the bottom.
I would never use an AC Delco filter, or any other filter that uses an "Ecore" design:
http://www.bobistheoilguy.com/forums...1809846&page=1
Old Feb 12, 2011 | 02:59 AM
damilleniumboy's Avatar
damilleniumboy
Wix or Napa Gold.
Old Feb 12, 2011 | 07:57 AM
JM20's Avatar
JM20
Originally Posted by damilleniumboy
Wix or Napa Gold.
Thanks for all the replies!
In doing a little more research on the Wix/Napa...are they supposed to be identical? The specs appear to be a tad different. I think I'm getting too deep on this issue
Wix Specs:
Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Napa Gold:
Flow Rate : 7 - 9 gpm
19 Micron
So is a higher Micron rating better?
Thanks again!
Old Feb 12, 2011 | 09:38 AM
timritchieblue's Avatar
timritchieblue
getting a wix or napa today
Old Feb 12, 2011 | 01:44 PM
killain's Avatar
killain
Oldtimer
Default Oil filter choice !
I used to just use the PH46, but they changed it to PH46E, which I believe I read is all about the packaging and not anything about the filter itself. I could be wrong. But I switched to a Mobil-1 filter with synthetic media inside it. They really don't cost any more tha a PH46E. And since I only change the oil and filter once a year, I use the Mobil-1filter.
But I believe, I read here about the different filters, any brand and they are all made by one company with a lot of different lables ? Wix seems to be a great filter. I haven't read anything negitive about them ?
Old Feb 12, 2011 | 01:58 PM
PETE O.'s Avatar
PETE O.
I've used AC Delco, Wix, Mobil 1, Fram and I'm now using Purolator One. Honestly, I think they all do the job but the Purolator just makes me a little more confident, for some damned reason.
Old Feb 12, 2011 | 02:08 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Wix for my fleet
Old Feb 12, 2011 | 02:39 PM
  #33
timritchieblue
car quest filter, (with the made wix) on the box
Old Feb 12, 2011 | 02:40 PM
  #34
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
Gee I thought everyone got the message that Wix is the best when it comes to oil filters.
Old Feb 12, 2011 | 06:20 PM
  #35
Z28ImpalaSS's Avatar
Z28ImpalaSS
Definetly over thinking this. Wix or Napa Gold.
Old Feb 12, 2011 | 06:31 PM
  #36
Black04Z06's Avatar
Black04Z06
Originally Posted by 0331MARINE
This thing never gets old.....
The simple solution is to move on? The bit*hing never gets old either
To answer the OP's question. I've had no problems with Wix or Mobil 1 filters. I stay away from Fram!
Old Feb 12, 2011 | 06:36 PM
  #37
firefighter813x's Avatar
firefighter813x
what oil?? hahahahaha
To Please Help With Oil Filter Selection!
Old Feb 12, 2011 | 06:42 PM
  #38
BenC5's Avatar
BenC5
Because of CF and the threads of the past, I switched to using NAPA Gold oil filters for my C5. Easy to get and not too much more than anything else. Like $6 or so.
Old Feb 12, 2011 | 07:04 PM
  #39
Rebel 1's Avatar
Rebel 1
Only AC Delco for me. The factory uses them and warrants the drivetrain for 5yrs./ 100,000 miles. Great by me.
There are Many LS engines running over 300,000 miles running Mobil1 and Delco filters. You can pay more but there is No Better Filter than Delco.
Old Feb 13, 2011 | 10:13 AM
  #40
Black04Z06's Avatar
Black04Z06
What tests have been conducted to back this up?
