C5 defroster vent grill
Old Feb 12, 2011 | 01:42 PM
mike-ssi's Avatar
mike-ssi
Default C5 defroster vent grill
Has anybody replaced one? I'm curious if it's DIY and how hard it would be.
Thanks,
Mike
Old Feb 12, 2011 | 04:31 PM
Jistari's Avatar
Jistari
Dont see much around it, never did one though. If its the grille (part numbers from the manual 10400366 or 67) it looks like it just lifts out.
Id give it a careful shot.
Good luck
Old Feb 12, 2011 | 07:11 PM
Gitusum's Avatar
Gitusum
they just pop out then twist the sensors out of the ends and its as easy as that! if you are needing 1 i have 1
rick
Old Feb 12, 2011 | 07:37 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
rick
Put be careful popping it out.....the individual grills are a bit fragile.
Old Feb 13, 2011 | 02:02 PM
mike-ssi's Avatar
mike-ssi
Thanks for the input guys-mine disintegrated when I had it detailed and I don't know if the guy even realized because the the pieces I pulled out were as brittle as could be.
So yes, Rick, I definitly want to replace it. How much do you need for it and is it dried out or fragile at all?
Old Feb 14, 2011 | 05:02 AM
Gitusum's Avatar
Gitusum
I will take $25 shipped for it and it came out of a 02 with 26k miles on it and is in great shape
Rick
Old Feb 15, 2011 | 01:29 PM
mike-ssi's Avatar
mike-ssi
Works for me-how do you want to do it?:
Old Feb 15, 2011 | 03:28 PM
Gitusum's Avatar
Gitusum
paypal works rikk_t@hotmail.com
Rick
Old Dec 27, 2011 | 04:53 PM
HighInFiber's Avatar
HighInFiber
I have the same problem. 3 slats were missing a few weeks ago. Today, I think 8 are gone...
Old Dec 27, 2011 | 09:09 PM
brianrandolph's Avatar
brianrandolph
6th Gear
I need one too! I bought my car in Virginia where they have to have a sticker in the front windshield, and while removing it, I barely touched the defrost vent and it shattered! It is the shale/neutral interior but I have been looking and can not find one in that color so I guess a black will work! It is a 2004 model
Old Dec 28, 2011 | 10:44 AM
HighInFiber
Same here... Shale. There is a vinyl primer and vinyl die that should help match the color. I also have a broken visor retainer, the part next to the rear view mirror. Do you have the dual AC setup? I have found several grilles for the non-dual AC, but none for the dual AC.
Old Mar 17, 2012 | 08:55 AM
HighInFiber
I just ordered a used one off Fleabay. 25 bucks and change, shipped.
Old Aug 25, 2012 | 01:47 PM
heiligdj's Avatar
heiligdj
2nd Gear
I need one for my 2003 50th anniversary - can't locate hte front defrost grille. 303-358-5180 Dan
Old Aug 27, 2012 | 11:41 AM
voda1's Avatar
voda1
Just checked - 10400366 discontinued. None in the dealer locator chain or Vintage.
Old Aug 27, 2012 | 01:14 PM
heiligdj's Avatar
heiligdj
2nd Gear
Default 2003 50th annv defroster grille?
Anyone know where I can get a used one? Craig's list and Ebay came up empty.
Old Aug 27, 2012 | 03:42 PM
HighInFiber
Black C5 defroster grille, dual AC
Old Apr 18, 2013 | 06:56 AM
Mitcheal's Avatar
Mitcheal
4th Gear
does anyone know what goes in the drivers side hole on the center dash defroster vent? I know on the right side it is a sensor
Old Apr 18, 2013 | 05:33 PM
HighInFiber
Ambient light right, radiant heat left, cabin air temp by the key... I think...
To C5 defroster vent grill
