Suspension
Old Feb 14, 2011 | 05:18 PM
97Rob's Avatar
97Rob
Default Suspension set up advice?
Need some advice on setting up my suspension. While I Had to motor out of the car, I replaced to sway bars w/ C6 Z51 sways. This is a 97 C5 by the way. When to car gets to about 120-130mp it gets really loose or wobbly feeling. I have QA1 duals on the front and single adjustable on the rear.
I'd like just like to have it handle very well on the road. Will not be tracking the car. Oh yeah, have to had it realigned since replacing tie rod ends. They were replaced same time as sway bars. Not sure that it being a little outa alignment would cause this?
Old Feb 14, 2011 | 06:59 PM
HowlinC5's Avatar
HowlinC5
If the alignment is off or a tire is out of balance it gets worse the faster you go.
Old Feb 14, 2011 | 07:46 PM
97Rob's Avatar
97Rob
Yeah, I was think that could contribute. I was wondering if someone had a similar set up and could get me started on the shock settings.
To Suspension
