Blinker problem
Old Feb 15, 2011 | 04:04 PM
garywalsh's Avatar
garywalsh
Default Blinker problem
Has anyone experienced an intermittent problem with the blinker system on C 5s?. The turn signal will start to blink and then stop. Five minutes later it will work again. Then it won't work at all. Any suggestions?
Old Feb 15, 2011 | 04:12 PM
GREENJOE's Avatar
GREENJOE
My '01 has the same problem. Someone will soon reply as to how to fix the problem, but in the meantime, switch on the emergency flashers for a second or two. Then try the turn indicator.
Old Feb 15, 2011 | 04:17 PM
Wop1's Avatar
Wop1
This is not the first time for this question, search the forum for more replies. But, the short answer is the signals go thru the hazard flasher, which is a real time consuming PITA. Cheap, simple, effective solution is a digital flasher that plugs into the circuit, about $49 and a 1/2 hour of your time to plug it in. There is a vendor that sells on the Forum that offers this. I can't recall their name, but a search should bring them up. It worked for me, 4 years in my car now.
Old Feb 15, 2011 | 04:28 PM
BevoZ06's Avatar
BevoZ06
St. Jude Donor '11-'12
This has happened only once to me in my C5 Z06. I switched on the hazard flashers for a few seconds. After I turned them off the turn signals worked just fine.
Old Feb 15, 2011 | 04:30 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Bingo......and you won't look back.
Old Feb 15, 2011 | 04:36 PM
BT-01-vette's Avatar
BT-01-vette
Corvette Enhancements is the company you are looking for the by pass switch
Old Feb 15, 2011 | 05:12 PM
f6john's Avatar
f6john
I was going to suggest changing or at least topping off the blinker fluid but it sounds like there is now a better alternative.
Old Feb 15, 2011 | 10:21 PM
TNRAT's Avatar
TNRAT
I posted a thread about the signal problem about a month ago....the fix was a $57 part that takes 30-40 minutes to install...
Below is a link to the part you need..
http://forums.corvetteforum.com/c5-p...harnesses.html
Old Feb 15, 2011 | 10:25 PM
Kale's Avatar
Kale
Be careful not to over fill.
Old Feb 16, 2011 | 01:07 AM
Rebel 1's Avatar
Rebel 1
I fixed this problem on our '02 for $10.00 and 45 min. labor Total.
All you need is the EL12 Electronic Flasher from Autozone for $10.00.
LINK - http://forums.corvetteforum.com/1569256474-post50.html
Thanks to "lionelhutz" for this excellent fix.
Old Feb 16, 2011 | 07:39 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
When the lamp filaments go bad, sometimes the filament will break and hang there, just barely touching the post it came off therefore allowing it to work and not work depending on vibration. The lamps don't last forever.
Old Feb 16, 2011 | 08:49 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
have not heard them referred to as "blinkers" in some time.....wow
Old Feb 16, 2011 | 10:28 AM
Rohan's Avatar
Rohan
Here was my problem. Over time the stupid connector pins got loose or something and started arcing with the bulb. I had to change the plug out.
Old Feb 16, 2011 | 06:18 PM
Sinister-one's Avatar
Sinister-one
Right now I have a very similar problem.... my turn signals work off and on. When they don't work I press the emergency flasher button on and off and my turn signals work again. BUT.... I have no emergency lights ! RUH-ROH !!
Old Feb 17, 2011 | 05:29 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i believe JWmotoring also has the harness and they are also a forum sponsor.
Old Feb 17, 2011 | 06:25 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Easy fix !
Get yourself some Blinker Fluid. It worked for my blinker issue. This is the good synthetic stuff too !
Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, factory quality blinker fluid should be changed every 150,000 blinks. Our blinker fluid lasts ten times that. KaleCoAuto high quality synthetic blinker fluid meets the highest DOT standards while not being in the least bit DOT legal! KaleCoAuto blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause. KaleCoAuto blinker fluid will not lose its viscosity even in the most extreme situations. Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car.
You can get it here...
http://kalecoauto.com/index.php?main...&products_id=6
Old Feb 17, 2011 | 06:51 PM
mpride's Avatar
mpride
Originally Posted by Toque
Easy fix !
Thats too funny. I guess I'll have to get some. Do they make a non syntehtic?
To Blinker problem
Old Feb 17, 2011 | 06:58 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
You can also just replace the hazard light switch. It is a PITA to replace, but that is the problem. I replaced mine when I added the HUD. Its been 5 years now and no problem since.
Old Feb 17, 2011 | 07:25 PM
dgrant3830's Avatar
dgrant3830
I'm still on the original hazard switch and its all still working...over 300k miles
Old Feb 17, 2011 | 08:40 PM
TNRAT's Avatar
TNRAT
Rub it in................
