Getting new tire mounted
Old Feb 20, 2011 | 08:16 AM
ltrz's Avatar
ltrz
Default Getting new tire mounted
I need to have my new tires mounted and ballanced. Does any tire place do corvette tires? I am worryed about them messing up the chrome rims. And are the pressure sensors still reuseable?
Old Feb 20, 2011 | 08:19 AM
DeeGee's Avatar
DeeGee
I guess its down to the quailty of the tire shop but most should cope with runflats.
Make sure they unscrew the nut holding the TPS in the rim and drop the TPS inside before they take the tire off. The machine can damage the sensor otherwise.
Old Feb 20, 2011 | 08:42 AM
Good advice. Most shops can mount and balance a Vette tire, but obviously some are better than others. If you have runflats, they are much harder to mount/dismount than the non-runflats and a shop may choose to not attempt it or will charge considerably more to do the work. Ask before you let them begin work.
Old Feb 20, 2011 | 08:47 AM
sfc rick's Avatar
sfc rick
Discount Tire, Tire Rack, it's not rocket science anymore, even Cadillac's and Kia's have TPMS and chrome rims are for everybody.
You really just need to look for a reputable tire shop.
Old Feb 20, 2011 | 02:41 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
I went to Tirerack.com, select tires, enter zip code and research the recommended shops. I called all the shops and spoke with a few on the phone and chose from there. Worked out just fine. Not everyone had a wheel balancer that could handle the 305/30/19 rears.
To Getting new tire mounted
