Convertible Tops
Old Feb 21, 2011 | 03:27 PM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
Default Convertible Tops
I have an 02 Convertible with the black top. The top appears to have "shiny" spots at the ends of a couple of the ribs. Looking closely it appears the canvas has been pressed down until it has become smooth in these spots.
The car only has 28K and is always inside.I think the marks are being made when the top is in the folded down position.
Has anyone had the same issue and/or found a way to get rid of these marks?
Thanks!
Old Feb 21, 2011 | 03:36 PM
Vettmann17's Avatar
Vettmann17
Thanks!
I too have an 02 Vert and I have exactly the same shiny spots on my black top. I think it's the way it's folded when down and causes almost a buffing condition rubbing on itself when you fold it down and bring it back up. Mine has looked like that for years and I'm so used to it I don't even notice it anymore. I'm sure it's a common condition on all the Vettes especially those with black tops as it's probabally more noticable in black than any other color. Don't sweat it, cause even if you replace the top it will happen again to the new one anyway.
Old Feb 21, 2011 | 03:38 PM
dougbfresh's Avatar
dougbfresh
Don't put the top up. (And then don't put the windows up).
Old Feb 21, 2011 | 03:39 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
do you usually keep the top down in the garage ? could be from that ?
Old Feb 21, 2011 | 03:41 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
It happens with my black top as well on my 2004 vert. I use a protectant which helps reduce it, however I try to keep the top up when parked in the garage or for any extended time to help keep the fabric stretched out.
There are (better) aftermarket tops offered that use fabric that prevents this type of wear from occurring, however they are pricier than OEM replacements.
I'm planning to upgrade to a custom gray color top when my C5 turns 10 in 2014. Sort of a birthday present...
Old Feb 21, 2011 | 04:07 PM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
Thanks Guys for the quick responses.
I think I need to get that partial can of flat black spray paint out of my garage before something really bad happens!
I was hoping for the mystical, magical silver bullet solution but at least its comforting to know I'm not alone
Old Feb 21, 2011 | 05:31 PM
Tom Keitzer's Avatar
Tom Keitzer
I have your answer. I too have an 02 black vert and the top is down most of the time. The "shiny spots" are caused by bouncing and rubbing when you drive with the top down. I was getting the same thing and it was driving me crazy!! I'm a bit **** about my baby and I admit it. Same mileage. Solution. I took an old sheet and cut two strips about 8" wide and the width of the top. I place them at the fold points of the top when I put it down and leave it down for a cruise. Problem solved!!! A bit of a pain but not that much. My brother-in-law has a C4 vert and actually wore holes though his canvas top from riding with it down and folded up 95% of the time. Good luck. Worth a try anyway. Sure worked for me!!!!
Old Feb 21, 2011 | 06:40 PM
Cardinal Flyer's Avatar
Cardinal Flyer
And if surprised by rain and forced to put the top up, you can't notice it from the inside anyway!
Old Feb 21, 2011 | 07:01 PM
04 commemorative
St. Jude Donor '17
seems like old towels in the folds might work well too when down
Old Feb 21, 2011 | 09:27 PM
gtzy's Avatar
gtzy
Try using a stiff brush to raise the fabric fibers in the affected areas.
Old Feb 21, 2011 | 09:47 PM
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
Yep...same problem here...thought it was an oil or something and tried to clean it with no success. I had a tan top when I first got the car and it didn't have these issues...
Old Feb 22, 2011 | 02:16 AM
rejoyce's Avatar
rejoyce
A towel or old sheet strips, as you suggest, will cure the problem. Thanks for the information
Old Feb 22, 2011 | 09:41 AM
dougbfresh's Avatar
dougbfresh
Many have had good luck with the Top dressing GM sells. Autogeek has one too I believe.
Old Feb 22, 2011 | 11:28 AM
MSG C5's Avatar
MSG C5
Sounds like a good idea. I have some extra sheets of thin memory foam that I used for a home project that I might stick in between the folds and try that.
Old Feb 22, 2011 | 03:41 PM
memmer's Avatar
memmer
Using a stiff brush on the top is a NoNo. will cause further damage
Old Feb 22, 2011 | 06:53 PM
GeneT's Avatar
GeneT
use spray on 303 Hi Tech Fabric Guard to protect your top from UV and also to waterproof it. It will also clear up those spots to some degree. With black, it's almost impossible NOT to get the stress point spots on your top. DON'T use a brush, unless it's a very soft one.
To Convertible Tops
