Pulling to the right
Old Feb 23, 2011 | 04:32 PM
XLR8KWK's Avatar
XLR8KWK
Default Pulling to the right
It seems like during hard acceleration and hard braking my C5 is pulling to the right. It is most noticable during braking.
Any ideas of where to look?
Old Feb 23, 2011 | 08:54 PM
brrymnvette's Avatar
brrymnvette
Could be a sticking caliper. I'd pull the front calipers and grease the pins really good and the parts of the caliper that the pads slide on. I actually had this same problem on mine. Would pull hard to the left when I got on the brakes.
If it's pulling to the right under braking, it would be the left caliper that's not giving the full clamping load. If it's pulling to the right under accel, it means the right front probably isn't releasing all the way.
So, I'd pull both fronts and grease the pins and points where the pads slide. Also, check your brake lines to make sure they are still good. Could be a bad hose that's causing it.
Old Feb 23, 2011 | 09:18 PM
Carcass's Avatar
Carcass
Could also be an alignment problem,if it's pulling to one side during acceleration also.
Old Feb 23, 2011 | 10:45 PM
jrose7004's Avatar
jrose7004
I'd say to check your alignment.
Old Feb 23, 2011 | 11:52 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
4 wheel alignment is in order - if there is a problem then they will find it and let you know what needs to be replaced - if not then a pot hole hit hard enough can throw things out of alignment!
Thanks,Matt
Old Feb 24, 2011 | 12:01 AM
damilleniumboy's Avatar
damilleniumboy
Or, did your tranny get pulled off the car lately? Mine pulled to the right when accelerating or braking. The car needs aligned as others posted.
Old Feb 24, 2011 | 01:26 AM
Manny De Leon's Avatar
Manny De Leon
Old Feb 24, 2011 | 08:28 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree...need to look at the rear alignment right away.
Old Feb 24, 2011 | 08:36 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I'm jumping on the alignment bandwagon as well. Found any potholes lately?
Old Feb 24, 2011 | 08:48 AM
romeospete's Avatar
romeospete
I agree with almost everybody here - sounds like you need an alignment check. I think the sticking caliper is unlikely the culprit.
Old Feb 24, 2011 | 09:08 AM
Vette Gator 01's Avatar
Vette Gator 01
Uhh, I wouldn't grease the points where the pads slide.
Just kidding, but I assume your talking about where the pads slide in and out on the metal clips. Don't grease the rotors!!
Old Feb 24, 2011 | 09:36 AM
Kmcoldcars's Avatar
Kmcoldcars
Many years ago the young kid a couple of doors down had just gotten his first car, a Mustang. When he drove it the brakes squealed. Having been told that when things squeal they need to be greased, he greased the brakes. Oh my, was his father unhappy about having to replace the brakes on the car. The kid was lucky. He did not hit anything with his car
Old Feb 24, 2011 | 01:15 PM
ffas23's Avatar
ffas23
Usually the problem you are experiencing is caused by a collapsed brake hose or one going bad. Inside a brake hose there is actually two hoses. The inner one sometimes ruptures causing the brake fluid not to fully flow back to the brake caliper when releasing your brake pedal so when you are braking again it will cause the oposite side of the car to pull to that side when braking. I had the same problem on one of my C-3's I owned many years ago. If I remember correctly it was the drivers side front brake hose that was bad causing the car to pull to the right.
Old Feb 24, 2011 | 03:51 PM
Good luck getting it solved.
Old Feb 24, 2011 | 05:34 PM
dgrant3830's Avatar
dgrant3830
Just the first posting/question from the OP and nothing more from him?
Old Feb 24, 2011 | 07:34 PM
PMPNSEZ's Avatar
PMPNSEZ
My $$$$ is on a wheel speed sensor. These cars are known to brake and pull to the right all on there own. Just my .02
To Pulling to the right
