Passenger window
Old Mar 1, 2011 | 03:59 PM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
Default Passenger window
I did a search and none came to my problem. I was messing with my codes on dic and now my passenger window wont go up after I rolled it down like it just completely stop with no sound of a bad motor what the problem fuse maybe?
Old Mar 2, 2011 | 02:13 AM
chrisk92's Avatar
chrisk92
do you know what going on?
Old Mar 2, 2011 | 02:47 AM
DeeGee's Avatar
DeeGee
Nothing you did on the DIC could have stopped it working. No idea why it failed but I'd say it's a coincidence.
I agree that the first thing to check is the fuses. Next you could look at the connector in the door hinge area (inside the rubber gaiter) and make sure it hasn't become disconnected. Pull it, clean it and check for chafing of the wire.
If still no luck I'd switch to the window motor. The relays are notoriously unreliable and often fail. You can change a relay easily and theres a How To on here. If you can find Bakersfield's thread on changing the door lock module you'll get the full rundown. If you cant access it let me know via PM with your E Mail and I'll send a copy.
http://forums.corvetteforum.com/show...ht=door+module
Old Mar 2, 2011 | 02:56 AM
chrisk92's Avatar
chrisk92
I checked it tomorrow when i wake up and i cant access the link cause it says i dont have the privledge to access it.
Old Mar 2, 2011 | 02:59 AM
DeeGee's Avatar
DeeGee
PM me and I'll send a copy
To Passenger window
