Altenator question
Old Mar 6, 2011 | 01:14 AM
99 hardtop 08's Avatar
99 hardtop 08
Default Altenator question
My guages have been reading from 13.6 to 14.4 volts. Is it time for a new altenator or should the charge vary that much? Any advice is appritiated. Thank you.
Old Mar 6, 2011 | 02:09 AM
Blown_2001Z06's Avatar
Blown_2001Z06
Yes it will vary
Old Mar 6, 2011 | 02:22 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
I don't see that you have a problem. Immediately after startup your system will usually charge at 14+ volts. As the engine runs, you'll see this voltage gradually drop, as the battery nears fully charged. A lead acid battery at full charge is approximately 13.6 volts.
Test:
With the engine running, take a voltage reading directly from the battery with a DC Volt meter. Then take a reading directly off the terminal on the back of the alternator to ground. Compare those readings.
The alternator voltage (power) goes from the back of the alternator, through the starter solenoid terminal and then up to the battery. If that path is compromised, you will have a voltage drop.
The dash meter gets its reading from circuits after the battery and there is a voltage loss. The readings off the dash meter and your voltmeter (battery) can be dramatically different.
Old Mar 6, 2011 | 07:53 AM
rws.1's Avatar
rws.1
If you are concerned drive to AutoZone. They will do a complete charging system diagnosis for free....
Old Mar 6, 2011 | 08:35 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You are right in the correct ALT Zone
Mine is pretty much the same
Thanks,Matt
Old Mar 6, 2011 | 10:18 AM
RedSoxFan's Avatar
RedSoxFan
If the reading is bouncing all over the place, check your battery connections. I was having this problem, and my radio display was also fluctuating, a fellow member suggested the battery connections and sure enough that was my problem. Tightened them up and it's been fine ever since. Also, my hold down clamp was loose which I believe led to the battery moving around enough to loosen the connections. I hope your solution is as simple!
Old Mar 6, 2011 | 10:35 AM
99 hardtop 08
I will check my connections and have Auto Zone do a test. Thanks for everyones help.
To Altenator question
