Coolant change
Old Mar 7, 2011 | 01:50 PM
ltrz's Avatar
ltrz
Default Coolant change
I had my 98 now for 6 months and do not know the last time the coolant was changed. I looked in the resivor and it looks like a orange color? Coolant or rust? What is the best typ of coolant to use. Are there any other things that I should know about before the change? Thanks.
Old Mar 7, 2011 | 02:42 PM
GK's Avatar
GK
Hi there,
There is a great write-up here: http://www.iammoon.com/c5tech/coolant_drain.htm
Old Mar 7, 2011 | 03:10 PM
discofreak's Avatar
discofreak
Dexcool is pinkish/reddish/orangeish.
But not quite as orange as the stupid crap Mopar puts in all of Chrysler's new engines.
As long as it doesn't smell like it's burnt (you'll know it if you smell it), then you're probably fine.
Dexcool, with age, tends to gum up and leave gunky deposits in your water passages. This heats up whatever flows the slowest enough to burn. If you smell that it's burnt, you need to forcibly flush the cooling system to make sure that you don't waste your time with new fluid.
Also, aluminum doesn't rust. At least, not like iron does.
Old Mar 7, 2011 | 03:21 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
You should be good.....the orange color is what you want.
Old Mar 7, 2011 | 07:04 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
GM recommends 5 years or 100K, any doubt, change it. it's not worth the damage for the cost. Use Dexcool and demineralized water.
Old Mar 7, 2011 | 09:30 PM
Rebel 1's Avatar
Rebel 1
Originally Posted by 8VETTE7
+1
I keep the coolant changed in all my cars and trucks regular maintenance.
2 gallons of Dex, you use 6 qts. and some distilled water costs me about $ 25.00 total.
Not worth it to me to try to run it longer, i've seen Many cooling systems in bad shape by running coolant to long.
Old Mar 8, 2011 | 12:27 AM
The Dex-Cool coolant is orange in color. My advice is if you don't know when the coolant was changed, then go ahead and change it. Best to be safe than have problems with the cooling system.
To Coolant change
