traction control system
Mr.Bill
I kept getting the Service ABS/Service Traction Control message and it wouldn't clear out. So I just said heck with it, pay Chevy the 100 deduct let them deal with it.
I would take mine off If I could with out messing up the computers or something. I have drove some really fast street rods over the last 48 years of driving, [much faster than 90% of the corvettes out there] and got along just fine with common sense.
Dave
Bag and twisty tie over the connectors and move away from belts/harm. Get back in and drive to send off your EBCM.
Putting back, the only real issue is get 2 middle of the 6 screws back started, but easy enough. It's easier than an OPS.
http://www.absfixer.com/catalog/prod...rb8mkab3rmrsm2
And yes, the link you posted is the (newer) EBCM for the C5.
Dave
When you go to install the EBCM, the two middle screws are a bit of a pain. I used tape, to hold the screws in place. I inserted the two screws just to the point that they stick out through the housing. Then used tape to hold them in place. They sit in the channel pretty well, and I just made sure that the tape held them in place. Do both before putting back on the manafold. This may save you from chasing screws under the car.
Slide it striaght on. Then feel around to make sure you got the torx driver on the screwhead, push in a little and you can feel as the screw is threaded up well and go to town. The bottom screws where easy for me to feel out and get them started with the fingers. You can see were they go from the bottom of the car, and do the job from down there, but you gotta be real skinny to get under without jacking up the car.
The top ones you can see, they are easy, and I did these last. Then install connectors and don't forget the connector keepers. Reinstall air briodge, start the car, no more ABS and traction control lights, whoo hoo!
I had more trouble putting the air bridge back on than the EBCM. I kept dropping those little plastic keepers and had to chase them more than once.
Good luck
