Check your halos!
Old Mar 12, 2011 | 08:16 PM
mcgilles's Avatar
mcgilles
Default Check your halos!
I posted a few months ago about 2 nearly identical phillips head screws that fell out of the back of my C5 one day in the garage. no one could identify them, neither could I.
Today I was trying out a new wax I picked up and heard a rattle coming from the bumper while cleaning it. the rattle was definitely coming from one of the halos. It didn't take much to put 2 and 2 together here. I pulled the light off and found one of the screws on the back of the assembly missing and 2 loose, so much so that they were making a racket with the slightest tap.
those screws aren't long enough it seems! they just barely thread into the assembly, I had to apply pressure to them to get them to thread in.
since I had 2 screws and only one empty screw hole I took the adjacent light out and it too was missing a screw, some of its screws were loose also.
one of them I couldn't get to screw in at all. if felt like just barely one thread had anything to bite into and it was stripped. had to use some black silicone to provide the waterseal and keep the screw in, that back panel is glued on anyway it looks like. screws used at the factory to hold the parts together while the glue sets maybe? either way they are needed now to keep water out of the light assembly.
Old Mar 12, 2011 | 08:39 PM
Carcass's Avatar
Carcass
I remember your original post-glad you found the source of the "mystery screws"
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Who is the manufacture of your HALO's?
Old Mar 12, 2011 | 08:40 PM
mcgilles's Avatar
mcgilles
Are there different manufacturers? I don't know. how can I tell? I just assumed they were all made by the same company.
Old Mar 12, 2011 | 09:13 PM
TP C5's Avatar
TP C5
Who did you buy them from?
Old Mar 12, 2011 | 09:39 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
What he said :
Old Mar 12, 2011 | 09:56 PM
mcgilles's Avatar
mcgilles
Richard at corvette enhancements
Old Mar 13, 2011 | 08:55 AM
Glad you found the source of the rattle and the missing screws. Haven't noticed anything like that on mine, but now you have my curiosity up. May pull out my lights and just double check that they are nice and secure.
Old Mar 13, 2011 | 10:19 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
This problem plagues all 5 generations of halo tail lights. Especially those that have been modified. The plastic "nut" on the inside is made of a relatively weak plastic that tends to self-destruct when the screws are removed.
The solution is as simple as getting a slightly longer screw from your local hardware store. If i remember correctly, a 3/4" #8 screw will be long enough to catch the sturdy part of the plastic on the inside and won't give you any more problems.
Old Mar 13, 2011 | 12:01 PM
mcgilles's Avatar
mcgilles
Thanks George!
I'll try to remember to pick some up, hopefully stainless. I think I lost one or two of the little rubber gromets but silicone can fix that. is that a #8 machine screw that you usually have good luck with?
Old Mar 13, 2011 | 01:00 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
I've been told I have a screw loose....now I know where to check. Thanks!
Old Mar 13, 2011 | 02:11 PM
LoneStarFRC's Avatar
LoneStarFRC
Good info. First I've heard of this problem.
Would you be so kind as to double-check the size and length to see if #8 x 3/4" is correct? I'm like mcgilles, I'd like to use stainless as well for no rust.
Thanks George.
Old Mar 13, 2011 | 09:06 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
george, thanks for sharing that suggestion and information.
Old Mar 13, 2011 | 11:39 PM
TheRadioFlyer
Supporting Vendor
Thanks George.
Correct. If your mounting holes have snapped off really deep, a 1" course-thread wood screw will carve new grooves and hold well.
Old Mar 19, 2011 | 06:33 AM
jdmvette's Avatar
jdmvette
Night Owl for life
CharDIN
http://chardin.en.ecplaza.net/
Old Mar 19, 2011 | 09:02 AM
TheRadioFlyer
Supporting Vendor
Originally Posted by jdmvette
I bet those guys love me
Old Mar 19, 2011 | 09:35 AM
RSchleder's Avatar
RSchleder
Price= negotiable
Delivery= negotiable
Inspection= negotiable
Yeah, I'll place my order yesterday
To Check your halos!
Old Mar 19, 2011 | 09:46 AM
bentonbobcat's Avatar
bentonbobcat
[QUOTE=RSchleder;1577099585]http://chardin.en.ecplaza.net/
Price= negotiable
I hope they take a post dated check !!!
Old Mar 19, 2011 | 10:54 AM
JuicedZ's Avatar
JuicedZ
Thanks OP! One of my screws was actually loose! Thanks to this thread I tightened with before it became an issue.
Old Mar 22, 2011 | 08:22 PM
Polar Jet's Avatar
Polar Jet
Thanks to the OP and George for the info. I should be getting my LED Halos any day now and just stumbled on this thread. Perfect timing. Hitting the hardware store tomorrow.
