Okay -
Passenger side works, driver's side doesn't....
Popped off the the clear cover and the light seems to be hardwired in??? Can these be replaced?
I wish I could get one out just to make sure I'm getting 12V to the damn thing.....
Soooooo, what's the trick????
You don't have to remove the mirror and take apart your visor. Pop out the clear plastic to gain access to the lights. The remove and replace the visor lights.
I have my vanity mirror detached from visor, but not clear to me how to reattach. It looks just like the photo you have here. There appears to be a pressure latch missing or something. What holds the mirror assembly to the pre-drilled holes drilled in support of visor under felt?? What am I missing here?
Originally Posted by Gr8Wht
Also, I'm in the process of putting in a Homelink device and rebuilding mine. Here's some pics that might help:
I may have inadvertently posted this in the wrong place in order to get a response???
I have my vanity mirror detached from visor, but not clear to me how to reattach. It looks just like the photo. There appears to be a pressure latch missing or something to attach the vanity mirror BACK on the visor. What holds the mirror assembly to the pre-drilled holes drilled in support of visor under felt?? What am I missing here?
One reason why I added the Homelink system was because my mirror assembly actually broke. In the second photo you can see the black plastic tabs that secure the mirror to the visor. I re-secured mine with zip ties from another post which seems to work well.
