Difference between 1997-2000 and 2001-2004 headers
Old Mar 19, 2011 | 06:43 PM
stas's Avatar
stas
Default Difference between 1997-2000 and 2001-2004 headers
Hi, I was wondering why aftermarket headers (SLP for one) are listed for 1997-2000 and 2001-2004 C5's. If installed on a '01 C5 Z06 will 97-00 long tubes fit?
Thanks.
Old Mar 19, 2011 | 07:00 PM
imavettegirl's Avatar
imavettegirl
later fits all, early only fit early models.
Old Mar 19, 2011 | 10:39 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Old Mar 19, 2011 | 10:47 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Smog pump injector tube location is different -
That can be adjusted too by cutting and lengthining the hose
Thanks,Matt
Old Mar 20, 2011 | 10:36 AM
imavettegirl
the exhaust ports are two different shapes.
Old Mar 20, 2011 | 10:51 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I thought it had to do with the injector pump(air pump) hook-up location?
I didn't know the ports were different.
Old Mar 20, 2011 | 10:53 AM
whitesmokels1's Avatar
whitesmokels1
If i remember, and someone correct me if im wrong, the early style heads had round exhaust ports and the later had a D shaped port. But i don't think they ever made headers that specifically matched the ports.
Old Mar 20, 2011 | 11:40 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks,Matt
Old Mar 20, 2011 | 11:43 AM
imavettegirl
call slp and ask why 2 different listings.
solved.
Old Mar 20, 2011 | 10:17 PM
madmatt9471
Is this an answer or a question?
I would love to hear more on this, this is new info to me - ohh actually pictures and head numbers would be better in order to support this claim.
Perhaps an article to elaborate on this statement or question
Thanks,Matt
Old Mar 20, 2011 | 10:37 PM
Mr.Bill's Avatar
Mr.Bill
The reason there is 2 listings is because of the location of the air pump.
Old Mar 20, 2011 | 10:38 PM
Mr.Bill's Avatar
Mr.Bill
Thanks,Matt
I agree.
Old Mar 20, 2011 | 10:39 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Old Mar 20, 2011 | 11:11 PM
imavettegirl
i agree that the op should call slp to make sure why two choices listed.
Old Mar 21, 2011 | 12:05 AM
stas's Avatar
stas
Thanks for your replies folks. It's not just SLP, other header companies also list two applications. I will try to call someone up tomorrow to get to the bottom of it and see if the early headers can be used on later C5's.
Old Mar 21, 2011 | 01:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's because of the air pipe fittings are different on the 97 -99, 2000, 2001-2004.
They can be made to fit or blocked off.
Old Mar 21, 2011 | 08:49 AM
madmatt9471
Don't forget to post what "THEY" say as well!
This is exactly what I said earlier in a post - this is the exact reason right here
Thanks,Matt
Old Mar 21, 2011 | 10:24 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
This is correct. I have a system designed for 01+ on my 99. I just upgraded the air tube and all was good.
Old Mar 22, 2011 | 12:37 AM
stas's Avatar
stas
Yup, just like people before me said, the pickup location for the smog pump is different (located on a different tube). The options for a later C5 is to either remove the AIR system or move the pickup to the correct tube.
Thx.
To Difference between 1997-2000 and 2001-2004 headers
