engine swap
Old Mar 19, 2011 | 08:02 PM
BBBob's Avatar
BBBob
Default engine swap
I have a 98 couple that I am going to pull the engine and replace with a 2004 Z06 LS6. Will the PCM from the 98 work OK with the LS6? Any "things" I need to watch out for ... Thanks!
BB
Old Mar 19, 2011 | 08:36 PM
Might want to post this in the C5 Tech section - bet the can give you some good advice.
Old Mar 19, 2011 | 08:43 PM
BBBob's Avatar
BBBob
Thanks, I did. I just joined and didn't realize I was in the general section.
BB
Old Mar 19, 2011 | 10:35 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Yes it will work, I had a 04 LS6 in my 99
Old Mar 19, 2011 | 10:38 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
BB
Yes! it will "BUT" the PCM will need to be reprogrammed on the Dyno due to the Cam being different and many other peramiters that will need to be addressed!
I have a '98 with 701 RWHP Supercharged and running the '98 PCM - it will work and it will work fine!
Thanks,Matt
Old Mar 20, 2011 | 08:55 AM
BBBob's Avatar
BBBob
Thanks! I appreciate the feedback!
BB
To engine swap
