I see posts all the time from folks who have lost or broken their C5 Bose Radio *****. I have been there myself.
So I did some searching and here are the AC Delco part numbers. Just search Google shopping for the part numbers.......but be ready for price shock as most are about $10 EAC
AC Delco 16195412 Small tone control *****
AC Delco 16195410 Volume, power ****
AC Delco 16189159 **** behind the volume ****
AC Delco 16195409 - Tuning Control ****
I found them from several vendors, the pic is from PartsTrain
These look nice. Has anyone run across a set of Chrome AC ***** that have black grooves/grips? I just installed a DD Kenwood DNX 6980 that has a chrome/black volume control **** and I would like to try and match it up.
They also sell just the climate control ***** that have the grips if that is all you need.
To make this as simple as possible finding these billet ***** I listed the two sites below. The original person above never listed where to purchase and after a lot of time searching the web I found them.
eBay; C5 Corvette Billet Radio *****, Item number 122187177882
Zip Corvettes; 05-13 Polished Aluminum Climate Control *****, item number X-2384
From what I read here the 05 will fit if you remove the sleeve.
The Zip 05-13 have to be modified to fit the C5 radio shafts. I cut the original centers out the *****. Drilled 1/2" hole for one center insert(left) and 3/4" hole into the chrome **** for the other(right). I used J-B Weld to glue them in and they work great.
