TPMS Help please
Old Mar 22, 2011 | 01:50 PM
99alvette's Avatar
99alvette
Default TPMS Help please
Hey guys my right front tps went out a month or so ago so I installed a new one during programing the left front sensor would not program so I took my magnet and stuck it on the back wheel (making the computer think it was the front wheel) a second later a honk so I know the control unit is good because it programed all the wheels exept the sensor in the left front.The sensor in question was working fine no signs of going out but no matter what I do it won't program. Do I need another 100 doller sensor or is there a fix.
Old Mar 22, 2011 | 01:58 PM
DaBoz's Avatar
DaBoz
I waited a week or so after a similar situation and after 100 or so miles of driving tried again.
They all reprogrammed immediately with no problems.
Old Mar 22, 2011 | 03:09 PM
DeeGee's Avatar
DeeGee
I'd say you need a bigger magnet (unlikely as it programmed on the other wheel) or a new sensor. Are you sure it was the correct part #? Did you get a sensor for the wrong year C5? (although $100 sounds like a 99 sensor).
Old Mar 22, 2011 | 03:24 PM
melvingregory's Avatar
melvingregory
If it's a 1997-2000, it should take a 315Mhz sensor. I bought four new ones from tirerack and installed them on my last tire replacement two weeks ago. They were $64.00 plus shipping each. Programmed just fine and I shouldn't have to worry about them. The orginial ones on my 98 were still working, but thought why mess with them later.
Old Mar 22, 2011 | 04:47 PM
99alvette's Avatar
99alvette
I ordered it from Gene at gm parts house his 97-00 are only $100 but the new sensor programmed fine one of the old ones didn't and it worked great before but why would the one wheel need a bigger magnet than the others?
Old Mar 22, 2011 | 04:50 PM
DeeGee's Avatar
DeeGee
Normally if the sensors wont program it's because the magnet is not strong enough
I've heard of 97-99 owners who fitted 00 sensors and then wondered why they wouldn't program (they work on different frequencies)
Old Mar 22, 2011 | 05:11 PM
paviesVette's Avatar
paviesVette
It's possible that it's just dumb luck and your old sensor battery bit the dust right around the time that you changed out the new one on the other tire. The new sensors from tire rack seem to be the way to go. I just purchased 4 new ones after getting new rims, and they work great on my 2000 TPMS system.
Keep in mind that the battery life time was only setup for 10 years from the factory, so you're on borrowed time with all your old sensors. I would suggest biting the bullet and getting all the old ones replaced.
Old Mar 22, 2011 | 05:51 PM
Corvette Don's Avatar
Corvette Don
All sensors are the same for 97-00. The Gen II sensors are 01-04.
Old Mar 22, 2011 | 06:14 PM
C5at57's Avatar
C5at57
You can rebuild the sensors yourself, it is not that hard to do. It takes me about an hour to 4 of them once they are out of the wheel. http://forums.corvetteforum.com/c5-t...batteries.html
Old Mar 22, 2011 | 06:19 PM
wkndwarrior's Avatar
wkndwarrior
why not replace the battery in them yourself? if you are dismounting to put in a new sensor just remove old one and replace battery for a fraction of the cost? just did that on my front pass side......then dang-it if the front drivers side developed a slow leak like a week later....since they dismounted it to fix the leak i went ahead and replaced the battery in that one myself also....just to be safe. pretty straight forward video on youtube on how to.
good luck
Old Mar 22, 2011 | 06:29 PM
jrose7004's Avatar
jrose7004
I'll bet that you need a new sensor.
Old Mar 22, 2011 | 08:04 PM
99alvette's Avatar
99alvette
I would replace the batterys but I have nothing to dismount/mount the tires
Old Mar 22, 2011 | 11:16 PM
Corvette Don
^Sent you a pm
Old Mar 23, 2011 | 02:25 AM
DeeGee's Avatar
DeeGee
Apologies for the typo!
Old Mar 23, 2011 | 08:10 AM
melvingregory
I thought about the going the route of replacing batteries on my old sensors when I changed to C6 Z06 OEM wheels and tires on my 98 vert a couple of weeks ago, but I just bought 4 new ones from tirerack and installed them when I changed. It saved me the expense of breaking down the other rims and removing those sensors, rebuilding them and making sure they worked okay. Tirerack charged $64.00 plus shipping for each. They are half that price on 01-04's. Theirs programmed with no problems. FYI, 315Mhz is the frequency on gen I sensors.
Old Mar 23, 2011 | 08:33 AM
Try this trick that I learned from another forum member - place the magnet right over the sensor location in the barrel of the wheel, not the on the front lip of the wheel when you do the programming sequence. I had a hard time getting mine to sync until I placed the magnet in the new location - worked like a charm.
Can't hurt to try this.
To TPMS Help please
