Old Mar 3, 2015, 12:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing
Print Wikipost
High powered LED Headlights
Old Mar 25, 2011 | 05:50 PM
nathancap24's Avatar
nathancap24
Originally Posted by VetteSiNz
Real LED headlamps are expensive. I installed 1 headlamp and 2 auxiliary lamp on my Harley and it cost me almost $1K for the set. These are as bright as HID. This is the same as mine. example:
http://www.youtube.com/watch?v=-gQ7t...eature=related
See, now that is what I am after. The light dispersion is so much better with this single LED lamp setup. Driving on the back roads of TX has me fearful of not seeing a deer or cow in the road at night.
Old Mar 25, 2011 | 05:52 PM
jrprich's Avatar
jrprich
Those look great!
Old Mar 25, 2011 | 06:12 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Originally Posted by JW@JWMotoring.com
they aren't going to produce enough light to be used as headlights.
now there's a statement from a man that should know just a little something about LEDs
I'll certainly be staying clear of these until the tech gets better.
Old Mar 25, 2011 | 07:15 PM
Dominic Toretto's Avatar
Dominic Toretto
Ghey.
-Alex
Old Mar 26, 2011 | 01:00 AM
itzza427's Avatar
itzza427
Interesting!! My first thought though is,,,as pricey as Harley's are,,why are those not stock!?! They sing the praises of how much better they are,,but you have to buy them AFTER you get a bike! Also thinking that a good amount of that price is "he Harley Tax" as well!! We like to refer to the "Corvette Tax",, It pales in comparison to Harley,,or motorcycles in general!! Sorry for the hijack!
Old Apr 26, 2011 | 01:08 PM
KansasGuardsman's Avatar
KansasGuardsman
3rd Gear
Default LED Lights Can Be Better than Incandescents
I design aircraft electrical/electronic systems, and there are LED's out there that will match or better any standard light. We are putting them on aircraft as landing lights, and tehy are fully FAA approved. But, they are EXPENSIVE. Around $400 per lamp. But as the quantities go up, the prices will come down. Real LED headlights we can afford are not very far off. Give it a year or so.
Old Apr 26, 2011 | 01:39 PM
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
Old Apr 26, 2011 | 03:19 PM
LCU11's Avatar
LCU11
Not the best choice for headlights on a C5, but those are the future of headlights...
within a few years, LEDs will be the standard for low power demand and higher light output, not to mention that they would last much longer
Old Apr 26, 2011 | 03:37 PM
Chicago1's Avatar
Chicago1
Still ugly as sin I see. Love my ACA and hid's.
Old Apr 26, 2011 | 03:40 PM
Bluefire's Avatar
Bluefire
<Barkely> Turable, turable, turable </Barkley>
but, that is only my opinion.
Old Apr 26, 2011 | 03:52 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Originally Posted by Mr.Bill
I have not read one good thing about LED headlights, They just don't have the ability to project the light at all, Unless things have changed, The picture posted, There is no way I could put them on my car...
My Harley's high and low beams are LED. Both are outstanding. Instant on, instant brightness, and cool operation anywhere you can actually touch. Also DOT approved.
Shouldn't be long until they make their way to cars...
(No reason someone shouldn't be able to retrofit the kit into a custom C5 housing, by the way)
The "Harley Tax" is mostly a myth. Those cost that much simply because that's what the technology currently costs. The lights, by the way, are the entire unit, not just bulbs. That means LEDs, lenses, face plate, protective glass, and connector.
Old Apr 26, 2011 | 04:56 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
a buddy of mine has the headlamp and fog lamp set up on his harley and i can tell all you disbelievers, they are every bit as bright as HID. if you look at the youtube video captioned above, you will see that it is actually a combination of the high power LED number and the projector type lense that makes the whole deal work. the lights only friend's harley are truly what you could classify as blinding. the LED lights being inquired in this post by the OP are about as worthless as you could probably get as they look like nothing more than a could of LED strings that couldn't light their way out of a dark garage. i certainly wouldn't want to try driving at night with those.
Old Apr 26, 2011 | 04:59 PM
  #33
Mrgogo's Avatar
Mrgogo
yuck!
Old Apr 26, 2011 | 05:28 PM
  #34
NealB's Avatar
NealB
sorry if this is a little off subject, but I was talking to the Electrical Dept guy in a Lowe's yesterday
they are phasing down compact flourescents in some applications and going to LED for home lighting, including selling 18 gauge wiring for home lighting circuits
he said they have LED outdoor floods now that are sold out shortly after each new shipment -- at about 10 times the price of incandescent floods
LEDs are a-coming in a lot of applications
a lot less energy and (if properly done) more light
Old Apr 26, 2011 | 05:43 PM
  #35
3dNomad's Avatar
3dNomad
I wonder what the dimensions of those lamps are? Makes one think. No ballasts makes for a simpler install I presume.
Old Apr 27, 2011 | 08:32 AM
  #36
Scissors's Avatar
Scissors
Do you mean the dimensions of the entire assembly, or of the LED "bulbs"?
The LEDs aren't actually bulbs, but rather rectangular LEDs on a circuit board backed with a huge heat sink. Since there are no traditional bulbs, the entire thing is one unit (board, LEDs, fascia, lenses, housing) which is placed directly in the headlight bucket. On the smaller buckets it's 5 3/4", and on the larger ones it is either 7" or 8" (I don't remember which).
The lack of ballast is awesome. All you do is plug the connector which used to be plugged into the halogen bulb into the back of the new unit.
Old Jun 28, 2011 | 09:48 PM
  #37
TWNTERBO's Avatar
TWNTERBO
Default LED headlights
Guys, Cady has been using LED headlights in the Platinum Escalade for years now. With that said, I doubt the quality of these are anything close to the OEM ones on the Cady. However, if they were similar, I can see how they would be just as functional and easier to install while using less energy.(lighter weight as well) Maybe if we had more light output/lumens details on these, I would consider being a g-pig and try them.
To High powered LED Headlights
Old Jun 29, 2011 | 12:31 AM
  #38
jdmvette's Avatar
jdmvette
Night Owl for life
Sweet, be the 1st.
Guranteed tho that the lumen output for these things is <1000.
Old Jun 29, 2011 | 03:06 AM
  #39
JETZ's Avatar
JETZ
Originally Posted by jdmvette
if you do get them please don't drive your car at night.
Old Jun 29, 2011 | 08:45 AM
  #40
mtndv8's Avatar
mtndv8
I agree. I've had my eye on a couple of Whelen products for some time now. They seem to have the best variety available. You can actually choose your dispersal/coverage pattern. The main limiting factor right now is cost, followed by the lights being designed to run on either 14 or 28 volt power.
Give it time. I'm thinking a couple years yet.
I know what I'm doing with them when they DO become available...
