Changing my battery
Old Mar 29, 2011 | 02:21 PM
Big Jay E's Avatar
Big Jay E
Default Changing my battery
Well my red top died after 8 years. Going to change it out.
I can't remember if I read on here that there is any particular sequence in how the cables get hooked back up to a hot battery??
Old Mar 29, 2011 | 02:30 PM
Fast Cop's Avatar
Fast Cop
Positive (red) is put back on first followed by the negative (black).
Old Mar 29, 2011 | 02:49 PM
DeeGee's Avatar
DeeGee
Clean the terminals before reconnecting
Reattach the positive cable and torque to 15 N-m (11 lb ft)
Reattach the negative cable and torque to 16 N-m (12 lb ft)
Reinsert the battery hold down retainer bolt and torque to 18 N-m (13 lb ft)
Good to see the occasional 8 year Red Top thread. Its a good battery if it's properly maintained.
Old Mar 29, 2011 | 05:31 PM
Big Jay E's Avatar
Big Jay E
Thanks guys
Old Mar 29, 2011 | 06:32 PM
ricknyc23's Avatar
ricknyc23
Old Mar 29, 2011 | 06:41 PM
c4cruiser's Avatar
c4cruiser
Originally Posted by hotwheels57
You may lose some of your memory features with the battery disconnected. They will require reprogramming at the DIC. It's not difficult, just an inconvenience.
Or you can use an inexpensive 9v battery memory saving device which plugs into the cigarette lighter receptacle and is available at most automotive suppliers. It'll retain the memory for the short time the 12v battery is disconnected. It looks like this...
If your OPTIMA is stone dead w/o any power remaining, it might be a moot issue. You might experience some erratic electrical behavior after a new battery is installed. It happens when the battery and computer can't "communicate".
The last time I replaced the battery in my C5, it only took about 5 minutes to do and I never lost any radio settings. Even the clock never lost the displayed time.
Some of the accessory catalogs state that the little 9v battery things that plug into the battery charger should not be used in C5's. Not sure why but I guess they have a reason for putting that warning there.
Our shop has a device that plugs into the ALDL port to save all the settings if a battery is to be disconnected for any length of time. It has a small 12v battery and we have left in plugged into a car for over 2 hours.
Old Mar 29, 2011 | 09:16 PM
Big Jay E's Avatar
Big Jay E
We will see. Haven't driven the C5 for a week and my wife discovered it dead. Nice to have a C6 as a back up
Old Mar 29, 2011 | 09:23 PM
Jet-Jock's Avatar
Jet-Jock
I believe the reasoning behind tightening the cables first then the hold down bolt as DeeGee described, is so you can put a torque wrench on the cables by tilting the battery slightly then after torquing, seat the lip battery base near the firewall and secure the battery with the hold down bolt. Otherwise, you will not be able to get the torque wrench on the fittings.
Old Mar 30, 2011 | 01:54 PM
Greenlight88's Avatar
Greenlight88
what size wrench should I be using on the battery cable bolt.?
Old Mar 30, 2011 | 02:04 PM
MCVetteLs6's Avatar
MCVetteLs6
i know its hard to beleive... but i jsut put a red top on this last weekend...
my car still have the stock original battery in it... its a 2001. i dont know how thats possible but wow
Old Mar 30, 2011 | 02:12 PM
Jet-Jock's Avatar
Jet-Jock
If I remember correctly it is 7mm.
You should make sure whatever battery you buy, that it has a 120RC (reserve capacity) rating.
Old Mar 30, 2011 | 05:52 PM
Greenlight88
would you have any suggestions on how to remove the bolt from the rubber boot? Don't want to damage the boot if I don't need to.
Old Mar 30, 2011 | 07:23 PM
Jet-Jock's Avatar
Jet-Jock
What rubber boot?
Do you have pictures?
Old Mar 30, 2011 | 08:39 PM
Greenlight88
on the battery cables where they connect to the battery. I'd like to pull the boot off to see if I have any corrosion going on, but didn't want to cut the rubber boot.
To Changing my battery
