Traction control almost killed me!!!!!!!
Old Mar 30, 2011 | 08:41 PM
SCRMNC5's Avatar
SCRMNC5
Originally Posted by Tesseract
That's precisely what it was doing. Braking. (and breaking?) That is how the car corrects itself in the event it detects a change in traction. It sounds like what happened is something went terribly wrong with the sensors which monitor your traction, so let's say your car pulled to the left hard, (you didn't say which):
ACTIVE HANDLING:
1.) the ECU was fed information from a faulty sensor that traction was lost. The sensors would be reporting a loss of traction with the rear swinging to the left. (car is in a clockwise spin)
2.) the system initiates the traction control "counter measure" IMMEDIATELY by reading the telemetry and determining the car needs to be corrected by "swinging" the rear back to the right. It accomplishes this by using your already forward momentum to it's advantage, simply by sending a signal to BRAKE the front LEFT wheel ONLY. This creates a "fulcrum" or pivot point at this tire, as forward momentum will now force a bias on the right side of the car.
3.) the system will do this until it achieves (close) to normal conditions. Effectively straightening out your car.
This is what I believe happened to you. The catch is, you never lost control. The car thought it did though and that's not good. I have never encountered this myself and this sort of scenario has always played out in my mind: "what would happen if the conditions were truly normal but the sensors went haywire?".
It's a freaky thought. I'm glad you are okay. Get it to a certified mechanic who knows this stuff well. Get it fixed ASAP.
I will surely be mindful myself from now on. I was under the impression that there was a whole lot more going on between accelerometers, gyros, speed, etc ... Meaning the system wouldn't have a knee jerk reaction because a single failure would contradict other read outs. This is how I understood it from GM themselves.
Glad you're safe. Good luck!
Thank you, this is exactly what had happened!!
Old Mar 30, 2011 | 09:18 PM
tony75A's Avatar
tony75A
Glad to hear you are alright.
At first I liked the idea of active handling until I found out what happens when it acts up. If this were my car I would have it removed/tuned out/disconnected.
That sounds like a very dangerous situation. I'm glad I picked up a low optioned FRC
Old Mar 30, 2011 | 10:18 PM
C5Wolfe's Avatar
C5Wolfe
Can you have it tuned out or removed? I hate it!!!
Dave
Old Mar 30, 2011 | 11:03 PM
Qwik01's Avatar
Qwik01
My traction control kicks in around 75 but I lose engine power. I have to turn it off on the highway. A friend of mine got a new C6 and his pulled him to the left and he ended up crashing into a telephone pole.
Old Mar 30, 2011 | 11:56 PM
cor28vettes's Avatar
cor28vettes
Originally Posted by JustinStrife
I've heard it happen with C6 Z06's... Not with C5's.
C5 issue was passed on to C6
http://forums.corvetteforum.com/show....php?t=1249213
go to post #35 & follow link
Old Mar 31, 2011 | 12:10 AM
herZ06's Avatar
herZ06
Exactly why I had mine turned OFF... when it fails, it FAILS. And it's dangerous.
Old Mar 31, 2011 | 12:11 AM
herZ06's Avatar
herZ06
Dave
My tuner turned mine off completely...
Old Mar 31, 2011 | 12:20 AM
98blownvette's Avatar
98blownvette
Thanks for the info and glad you are ok. Anyone know if this is common (not common incident I know) in any other make, model etc. other than very few c5's and c6's?
Old Apr 3, 2011 | 10:55 PM
SCRMNC5's Avatar
SCRMNC5
Does anyone know if this is something I can replace on my own?? If not, has anyone had any experience with this at the dealer and if so how much did it run?? Any info will help.
Old Apr 3, 2011 | 11:21 PM
corvette77's Avatar
corvette77
I am assuming you had the code for the steering position sensor. I did not replace mine myself, because you have to pull out the steering column. The sensor is at the base of the column. That being said, I took mine to the dealer (just last month actually), and it was just over $400 for the part and labor.
Old Apr 4, 2011 | 12:59 AM
TheDVS1's Avatar
TheDVS1
True, but when it works - which is 99.9% of the time - it can save your butt. At least it has for me...
Old Apr 4, 2011 | 09:40 AM
TorchRedRocket's Avatar
TorchRedRocket
Active handling is a really nice, high-tech feature that we should be thrilled to have on our cars. I would advise against ever having it turned off. After all, C5's are 7+ year old cars, and all cars require repairs to keep things in working order. Just always have problems with active handling addressed and fixed immediately!
Old Apr 4, 2011 | 11:59 AM
  #33
SCRMNC5's Avatar
SCRMNC5
11 codes
all have a C before them and an H after them
28 tcs
1222
1226
1233
1234
1235
1248
1278
1283
1287
1288
Old Apr 4, 2011 | 12:15 PM
  #34
turk2gk's Avatar
turk2gk
Happened to me twice! Since then I always turn it off as soon as I get in the car. I dont want anything to do with Traction Control.
Old Apr 4, 2011 | 12:19 PM
  #35
SCRMNC5's Avatar
SCRMNC5
It's not the traction control, don't be mistaken! Just by turning your TC off doesn't mean your active handling isn't ready to activate if your vehicle detects spin!!
Old Apr 4, 2011 | 12:55 PM
  #36
Bluefire's Avatar
Bluefire
It is not a TC issue. It is not an AH issue either. The AH is doing what it was intended to do. Unfortunately, the AH is acting on the bad information that the SWPS provided. I agree that the GM engineers should have designed a different algorythm to handle "bad" SWPS data.
Old Apr 4, 2011 | 01:51 PM
  #37
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Correct me if I am wrong Comp mode turns off TC only. Turning OFF system shuts down both AH/TC only ABS remains.
This is what I have gathered from various sections of the manual:
Summary
There are 3 modes
1) Traction Control Off, Active handling Off
2) Traction Control On, Active handling On
3) Competitive Driving = Traction Control Off, Active Handling On
Traction Control (TCS)
•This limits wheel spin by working the rear brakes and reducing engine power.
•TCS comes on automatically when you start the car.
•If it engages (i.e. if you start spinning the wheels and it kicks in to reduce spin), the DIC shows TRACTION SYS ACTIVE (momentarily)
•To toggle TCS on or off, press the Active Handling button on the center console briefly. This will also toggle the Active handling System in conjunction with TCS. The DIC will briefly display "TRAC/ACT HNDLG -ON" or "TRAC/ACT HNDLG -OFF".
•If it is OFF, then the skidding-corvette-rear-end light (TCS light on the instrument panel) is ON.
Active Handling System
•Active Handling helps maintain directional control by selectively applying any one of the vehicles brakes.
(The video has an interesting segment on this feature)
•Active Handling comes on automatically when you start the car.
•If it engages to regain vehicle control, the DIC says "ACTIVE HANDLING" (briefly).
•If you turn the Active Handling System Off, the traction control system will also be turned off. It is toggled on or off the same way the TCS system is toggled (see above)
Competition Mode:
•Competitive Driving mode allows the driver to have full control of the rear wheels while the Active Handling system helps steer the vehicle by selective brake application.
•When on, the DIC displays "COMPETITIVE DRIVING"
•To turn on Competition Mode, press the Active Handling button on the center console for more than 5 seconds.
•To turn it off, press the button briefly. Does the active handling/traction control then turn ON?
The manual states that ABS remains on with the traction control and Active Handling Systems off. I assume this means it also remains on when in Competitive Driving mode?
To Traction control almost killed me!!!!!!!
Old Apr 4, 2011 | 02:41 PM
  #38
RJRSW's Avatar
RJRSW
11 codes
28 tcs
1222
1226
1233
1234
1235
1248
1278
1283
1287
1288
That many codes sound like a larger electronic control problem then just the SWPS. If it only had thrown the c1288 it probably would be the SWPS but with all the others it appears it is beyond just the SWPS.
C1222 RF Wheel Speed Sensor Input Signal is 0
C1226 LF Excessive Wheel Speed Variation
C1233 RF Wheel Speed Circuit Open or Shorted
C1234 LR Wheel Speed Circuit Open or Shorted
C1235 RR Wheel Speed Circuit Open or Shorted
C1248 DRP Disabled (dynamic rear proportioning)
C1278 TCS Temporarily Inhibited By PCM
C1283 Excessive Time to Center Steering
C1287 Steering Sensor Rate Malfunction
C1288 Steering Sensor Circuit Malfunction
Old Apr 4, 2011 | 03:14 PM
  #39
herZ06's Avatar
herZ06
I tend to disagree with this, for myself of course-not speaking for others. I know when to push my car, when not to, and I know my limits as far as my driving ability goes. Since I've had it turned off, which has been since August of last year, I've not had a single problem with traction (or lack thereof) and I have never been in a situation I would consider dangerous to myself or others. I am not easy on my 600+hp, when the situation permits-I like to enjoy the performance.
Several times with the A/H, I would be doing NOTHING that should cause it to kick on, and it would kick on under normal acceleration onto the highway. This happened on several occasions and I felt like I was in danger, as well as those around me because the car felt the need to randomly brake hard to one side at 70mph. These are the ONLY times I have ever been scared behind the wheel of my car. Truth is, I'm cheap, and I'm not going to pay to fix something I don't like anyway. So for me, turning it off has been best. As they say, to each their own.
Old Apr 4, 2011 | 03:53 PM
  #40
SCRMNC5's Avatar
SCRMNC5
Did your tuner turn it off. I would like to turn mine off as well
