I tend to disagree with this, for myself of course-not speaking for others. I know when to push my car, when not to, and I know my limits as far as my driving ability goes.
Well let me say this, for those times when I push the car hard, I rarely have problems. For the time I hit a leaking sprinkler shooting water across a 270 degree freeway on-ramp at 1am and didn't see the torrent - it gently helped steer me back in the right direction. For the morning when I applied a fraction too much gas peddle after carefully making a right turn and it was below freezing outside - it made the recovery much simpler and less sphincter-squeezing.
I'm not saying I couldn't have recovered without it, but knowing it was there made it a simple matter of relax and steer where you want to go. When I'm really pushing the limit in good conditions in the twisties, it lets me slide around enough to have some fun.
It's for the unexpected that the AH system can be a real sweet insurance policy.
Wow! Great thread! I have owned high-performance cars for 25 years with no traction control or active handling devices---I guess I don't need any now. LOL
From: eustis FL Saved and blessed; what else matter?
A LOT of conflicting opiniopns here. Does anyone KNOW how to diable active handling? I suspect that turning off traction control does NOT totally diable active handling.
So I'm driving the other day on the highway, at about 75mph, and all of a sudden the car just pulls hard to one side and sort of felt like it was braking at the same time!!! I looked at the display and it was reading that the traction control had been engaged. Has this happened to anyone else. Or does anyone know what it is?? Thanks
Barry
Mine does this, it pulls to the right a time or two before the "service active handling" message comes on. It has given me pucker factor in the past, now I turn it off as soon as I start to move. The "service active...." message will come on eventually during my drive. Sure missed it the other day when it was pouring.
Replace your Steering Wheel Position Sensor. ~$300.
Try to imagine it malfunctioning WHILE it was pouring...
The "button" disables the T/C but not the A/H (at least on mine). You can permanently disable both through the use of one of many hand-held tuners or by taking it to a shop.
For me personally, I've had a few situations where the back end decides to step out while cornering under throttle (particularly wet-weather) and the A/H saves my butt. I keep it on unless I'm at an HPDE or practicing car control. I guess I might feel differently if it went the other direction and tried to kill me. The cool thing about the programmers is that you can switch it when you get to the track and then switch back when you're ready to go home.
It seems like this would warrant a recall if it happened much. I'd cerainly need to toss my shorts if it happened to me. Does anyone know if this is a function of a sensor just going bad over time/mileage/use? or if it's more likely that the sensor was damaged by user-error or excessive vibration, etc.? Are there certain years or models that are more prone to it?
That's good advice after the fact. But when you're in heavy traffic and it throws you into another lane or into oncoming traffic, it is obvious that is the WRONG way to find out the sensor is bad. The system is dangerous because it has no fail-safe mode. When a sensor malfunctions, a properly-designed system would deactivate itself. I will deactivate mine every time I drive simply because I don't want to die in the process of finding out I have a bad sensor!
It is VERY annoying to me when I let the tail hang out in a turn and it slams a brake on to straighten it out. I want my car to do what I want it to do, not what an electronic nanny wants it to do! That said, I'm sure that the majority of drivers are better off with the nanny in place...
i seriously thought you were joking, you know, like blinker fluid or stir the bucket of vapor lock. i had to google that to verify that really is there.
I posted on this a few years back; I was driving on the freeway in the rain at about 55 mph in 5th gear and my rearend just came around on its own for no reason at all. Consequently, I spun out - probably 3 to 4 full rotations - before ending up rolling backwards, facing traffic and in third gear. When it was over, my traction control had shut itself off. It was really incredible that nothing happened.
I took it to the dealer and they said that all was well; that my yaw sensor showed that I had lost control; and that I must've hit an oily patch - which was BS. Essentially, they couldn't tell me which came first, the chicken or the egg.
Later on, the traction control module went out and it was replaced under warranty (the part alone costs $1800).
I have a feeling that this is something GM knows about but has kept quiet. It's rare, but one of these days someone's going to get seriously hurt.
Sorry I wasn't able to post the fix before your SWPS took a crap. Stuff happens. I wasn't defending GM's S/W algorithm either. Just posting the fix for the issue. It happened to me too. Have a nice day
Originally Posted by Redeasysport
Uh .....PUSH THE BUTTON
Competitive Driving Mode
"The Corvette Active Handling system will be the first of its type to offer dual mode operation. In addition to an "OFF" mode, in which Active Handling is disabled, the system also allows the driver to select a "COMPETITIVE DRIVING" mode for autocross or gymkhana competitions. In this mode, the Active Handling system remains fully-functional -- measuring steering, yaw rate and lateral acceleration inputs as well as applying individual wheel brakes as required -- but the traction control system is disabled, allowing for some wheelspin and oversteer that skilled drivers often find beneficial in competitive driving."
-GM press release
Had it happen to me on the track @ VIR (forgot to turn all that traction control suff off when I went on the track). Crested the rise on the back straight doing better than 140 mph and had braking kick in on each wheel in quick succession. Weird experience. Guess the computer thought I was in an out of control situation when the car "got light". (Maybe the sensors were also at fault, old, etc.) Never actually lost control, but it still made my heart skip a few times! It's one of the reasons I no longer try to push it past 140 on the track.
In comparrison and when only 3000 miles new, I had the car on one of the German Autobahns (had it delivered to me in Germany when I was stationed there with the USAF) with all the electrons on and reached an indicated 172 mph before I figured it was time to slow down. No problems there.
Just to confirm I have had some heavy pulling on my 2004 coupe. It would last a few seconds and back to normal. I just checked th codes and I have C1228H and c1283H.
As I understand it the button on the console will keep that from happening??
Will I also get messages even if I fix the wheel sensor for the C1228 code? IE I will still get the message : Service TC ABS etc???
The fix? Clean up of connections, grounds etc?
