[Z06] Broken lug stud
Old Mar 30, 2011 | 01:06 PM
z06nightmare's Avatar
z06nightmare
4th Gear
Default Broken lug stud
Need size of center nut holding rear wheel hub and size of hex heads to take hub off to replace broken lug stud. 2003zo6. Thanks
Old Mar 30, 2011 | 04:07 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
33mm, but I've replaced front and rear broken studs with the hub still on the car. The fronts are easy enough, the rears you have to drill a hole in the backing plate large enough to tap the bolt out.
