Added sea foam engine will not start
Old Apr 2, 2011 | 09:53 PM
nfratto's Avatar
nfratto
Default Added sea foam engine will not start
Added sea foam to throttle only small amout engine went to reduced power. Engine shut down will not restart help. C5 2003 auto 44000 miles stock
Old Apr 2, 2011 | 10:05 PM
tlc0706's Avatar
tlc0706
Sea Foam should be added via brake booster vacuum line or the small vacuum on the side of the throttle body......They do make a spray, however...How did you get it in? Worst scenario, hydro lock...
Old Apr 2, 2011 | 10:33 PM
robert miller's Avatar
robert miller
Unhook the batt on the car for about 1 hr to make sure. Then hook it back up. That will lose the reduced power. When you start it back up make sure you keep it running by just giving it a little gas...
Old Apr 2, 2011 | 10:52 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
How fast did you dump in the "little bit"?
Although pulling in via the brake booster or PCV orifice is typical, it doesn't really matter where it's pulled in... in fact it doesn't matter at all anyway because it's a waste of time.
I seafoamed forever, still got pinging, pulled the heads and had tons of carbon to scrape. ALL additives are snake oil.
With that being said, pull your codes (easy to do on your dash, just search if you don't know how)... write them down, clear them all... most likely the car will start. If not, other codes will be produced. Post what they are.
If you'd rather phone support, PM your number, I'll be up till midnight and I'm in good mood, I can walk you through this. Git 'er done!
Old Apr 2, 2011 | 11:30 PM
nfratto's Avatar
nfratto
Only added about ten seconds worth it was the spray that can go through the throttle plate
Old Apr 2, 2011 | 11:46 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Again, what are the codes?
Old Apr 3, 2011 | 12:07 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I agree with both of these - we need the codes and you need to reset everything "AFTER" we know the codes -
You can access them off the DIC - if you don't know how let us know.
Thanks,Matt
Old Apr 3, 2011 | 12:12 AM
nfratto's Avatar
nfratto
I will pull the codes tomorrow car is in driveway thanks for the help so far
Old Apr 3, 2011 | 12:13 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Wish you called, have some ideas (even without codes) but typing on this iPhone sucks.
If the engine was running and you took off the airbridge to spray in the snake oil, you were taking the MAF (mass air sensor) out of the loop, hence the reduced engine message (and corresponding code stored min the computer).
Put the air bridge back on and turn the key.
Off to bed, good luck... Zzzzz
Old Apr 3, 2011 | 12:14 AM
Major Dump's Avatar
Major Dump
How long did you let it sit after? Does it just turn over and not fire at all?
Old Apr 3, 2011 | 11:05 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I thought the same thing reading the story.
You took the MAF out of the circuit by disconnecting the air bridge to spray inside the intake manifold. Not good.
Toque
Old Apr 3, 2011 | 11:55 AM
madmatt9471
UPDATES?
Let us know as soon as you get back at the Vette!
Thanks,Matt 661-406-7516
Old Apr 3, 2011 | 03:32 PM
killain's Avatar
killain
Oldtimer
Default Once the trouble has passed. . .
Make sure to change the oil & filter. I'm sure you overloaded the cylinders and contaminated the oil as well.
Old Apr 3, 2011 | 06:43 PM
vette.mix's Avatar
vette.mix
No updates? curious if OP got his Vette running
Old Apr 3, 2011 | 06:52 PM
robert miller
I would look at make sure for your quesion to him on this. But with that code coming up on his display it will never start until that is out. Only way is to unhook the batt for a t least 1hr or to do it by the book on hold this and hit that and then do this crap with the key on acc.
Old Apr 3, 2011 | 07:00 PM
killain's Avatar
killain
Oldtimer
Default Yep !
Yeah ya got a good point there. I hope he got it running, a hell of a lot of guys have done the Seafoam clean-up and this is the first time I've heard of a problem. Sure it'll smoke like all get out, but the pistons will be cleaned up and his piston slap should be gone for awhile.
Old Apr 3, 2011 | 08:10 PM
oakvillec5's Avatar
oakvillec5
Curious to know the outcome????
To Added sea foam engine will not start
Old Apr 4, 2011 | 02:27 AM
Quick Draw's Avatar
Quick Draw
Highly unlikely that 10 seconds of spray "overloaded the cylinders and contaminated the oil as well".
Old Apr 4, 2011 | 06:01 AM
baxsom's Avatar
baxsom
Totally agree, if seafoam worked as well as it is reputed it should clean a carbon crusted intake valve if soaked in it right? I soaked a 40 year old intake out of the old head in my C3 for a month and when I finally remembered it was in there was no noticeable change in the hard caked carbon on the valve. People say that it is working because it is smoking when applied. That smoke is the light petroleum and naptha burning off.
Old Apr 4, 2011 | 08:42 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I was getting pinging and knock sensor codes and Seafoam kinda worked the 1st time around for a little while... it still pinged though and in short order the knock codes were back.
I Seafoamed again to no avail, the picture below was about 300 miles after the last treatment.
When I pulled the heads, the backs of the intake valves were fairly clean and also the intake ports.... but the chambers, piston tops, and the back of the exhaust valves were hard caked. I actually needed a grinder to correct the exhaust valves, my little drill powered wire wheel had no chance.
Seafoam (and Techron) does nothing except clean the backs of the intake valves with regular use.
