polished thin spokes clear coated?
Old Apr 3, 2011 | 04:53 PM
Phanni's Avatar
Phanni
Default polished thin spokes clear coated?
I've got the so called polished thin spokes on my 2000. Does anyone know if these are sprayed with clear coat at the factory? The inside of mine seems to have what looks like peeling clearcoat. They polish up pretty good inside, but there is still some 'edges' where it lookks like the clear is breaking away.
If it is clear coat, is there a way of removing the existing and reapplying?
thanks
Steve
Old Apr 3, 2011 | 05:52 PM
MAC5's Avatar
MAC5
The OEM polished thin spokes are clear coated. They can be refinished by removing the clearcoat, polished and clearcoat reapplied. Options include on your own or professionally.
Old Apr 3, 2011 | 05:58 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
definitely clear coated. Several people have used metal stripper to get rid of the clear coat. Then you can actually polish them nicely. The clear dulls out (gets cloudy) after a while and there is no way to polish it without removing it.
Old Apr 3, 2011 | 06:33 PM
vette.mix's Avatar
vette.mix
Old Apr 3, 2011 | 10:54 PM
Good advice here. If the clear is peeling in spots, then stripping the wheel, polishing the aluminum if needed and reapplying the clear coat will make them look like new.
Old Apr 4, 2011 | 02:07 AM
Quick Draw's Avatar
Quick Draw
Can they be clearcoated with tires mounted?
Old Apr 4, 2011 | 02:17 PM
Phanni's Avatar
Phanni
Hey thanks guys.
I'll find some stuff to remove it then respray,,,
Old Apr 4, 2011 | 02:19 PM
Phanni's Avatar
Phanni
the clear coat can be bought in spray cans. I'm thinking it can be applied by masking the tires. I don't think it'd be a god idea to spray the clear coat onto the rubber, it'd yellow pretty fast (Just a SWAG)
Old Apr 4, 2011 | 02:22 PM
ChromeC5's Avatar
ChromeC5
Let us know how it turns out! Take pictures.
Quick Draw: If you cover the tires, you can spray them with the tires on. It may peel pretty quickly where the tires meet the wheels.
Old Apr 4, 2011 | 03:31 PM
BitViper's Avatar
BitViper
Ive been thinking of taking some 0000 steel wool and "scuffing" my barrels so they look like they're satin finished.. then using VHT clear coat... getting really tired of pulling teh wheels to polish the barrels
Or just painting them (the barrels) silver
Old Apr 4, 2011 | 04:24 PM
VETFEVER's Avatar
VETFEVER
Don't bother re-coating your wheels as your "home applied" clear will flake off in no time.
Instead remove the clear coat by using a product called Tal-Strip made by Marhyde (google it). It comes in spray and wipe on formats. I used less than 2 cans of the spray to do 4 wheels. It will remove the clear coat easily.
Then, just polish the bare metal with any good polish - if you want them to look better then new, use one of those foam polishing ***** and a drill.
After that, just hit the wheels with synthetic wax (like Rejex) about once a month.
The thin spoke wheels have such simple thin spokes with no nooks and crannies that keeping them polished is a breeze.
Cheers
vetfever
Old Apr 4, 2011 | 04:36 PM
dankhts's Avatar
dankhts
Jack - did you remove the clear coat with your tires on or off the rims?
Old Apr 4, 2011 | 06:42 PM
BitViper's Avatar
BitViper
Cheers
vetfever
sure Rejex works but how do you apply Rejex w/o adding micro scratches in the polished wheels
Old Apr 4, 2011 | 08:41 PM
corvettebob1's Avatar
corvettebob1
What everyone is refering to as clear coat is really a clear powder coat as so I have been explained by 3 different wheel refinishers.
GM does have a paint that body shops can and do use for refinishing of wheels but it is an aircraft paint and is $$$$.
If you really are ging to all the work of refinishing get it done right.
Old Apr 4, 2011 | 08:50 PM
VETFEVER's Avatar
VETFEVER
Just like you wax your car - with a fine cloth....or you can just polish them once a month - the wheels have such a simple design - 5 little smooth spokes - easy-peazy....
Old Apr 4, 2011 | 08:55 PM
VETFEVER's Avatar
VETFEVER
I did it with the tire still on - I just masked them and went at it. The Tal-Strip product works almost instantly and you rinse it off with water from a hose so the rubber is barely exposed for just a few seconds....
Or you can do them with the tires off.
Please note that the barrels are also clear coated even on the inside and you should mask these areas off as the clear coat on the inside helps protect the rim over it life from moisture that typically builds up over time (compressed air is often very humid)...
Easier to just do them with the tires still on...
To polished thin spokes clear coated?
