Blinkers sometimes work sometimes dont work.
Old Apr 3, 2011 | 10:52 PM
crAzy's Avatar
crAzy
Default Blinkers sometimes work sometimes dont work.
Im assuming my hazard switch switch is going out? 95% they will work then they will just stop working. Any input on what is going out?
Old Apr 3, 2011 | 10:57 PM
TNRAT's Avatar
TNRAT
Surprised you havent read about this as long as you have been a member here....click on the link below to a thread where I asked the same question...read thru and you will see several fixes..the switch did the job for me..
http://forums.corvetteforum.com/c5-g...-problems.html
Old Apr 3, 2011 | 11:54 PM
Jeff in Den's Avatar
Jeff in Den
Wasn't the hazard switch for me, it was the multi-function turn signal switch. I trouble shot it from the turn signal light backward thru the fuses and relays to the connector under the steering column. Removed the switch from the column, disassembled it and found some of the contacts were in need of some emery cloth and readjustment. Total cost...$O dollars, but about 2.5 to 3 ours of my labor.
Old Apr 4, 2011 | 09:03 AM
crAzy's Avatar
crAzy
I pressed the hazard light button. Then checked blinkers and they worked again. So im assuming it has to be the switch going out?
Old Apr 4, 2011 | 09:23 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
In most cases it is the 4 way flasher/ Which is a pain to replace,What I did was install a new Hyper Flash harness and that took care of my issues, Get ahold of JWMotoring.com a vendor here and he can fix you right up.
http://shop.jwmotoring.com/product.s...2&categoryId=4
Plug N Play.
To Blinkers sometimes work sometimes dont work.
