Outside temp sensor
Old Apr 4, 2011 | 12:44 PM
Mark I's Avatar
Mark I
Default Outside temp sensor
I know this was out there a while ago but I couldn't find it.
Where is the sensor located for the outside temp reading? It always reads high on my car and that throws the climate control off.
Old Apr 4, 2011 | 01:18 PM
melvingregory's Avatar
melvingregory
It's located on the passenger's side under the bumper towards the radiator. If you remove the access panel underneath you should be able to follow the wires to it.
Old Apr 4, 2011 | 01:32 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
As stated above, I replaced mine from the top and it took 3 mins.
Mr.Bill
Old Apr 4, 2011 | 01:39 PM
DeeGee's Avatar
DeeGee
This is the sensor:
Old Apr 4, 2011 | 03:06 PM
Simple replacement and for once, not a very expensive part to replace.
Old Apr 5, 2011 | 11:48 AM
Mark I's Avatar
Mark I
Thanks!
Old Apr 5, 2011 | 12:11 PM
chill99's Avatar
chill99
I took mine to the dealer (under warranty) because the temp was always reading high. The warmer it was outside, the more off the temp was.
Dealer said per GM is was within tolerance for the temp to be off by like 5 degrees either way, if I remember correctly. Mainly what I remember is thinking that the accepted tolerance by GM was ridiculus. Every other vehicle I own or have owned with an outside temp gauge has always been dead on correct.
The dealer supposedly adjusted the temp guage somehow? But I don't think it's much better, if any.
Do you guys think replacing it would fix that problem? Do your gauges show the correct temp in all temp ranges (hot to cold)? Is my problem just because I have a dark colored vehicle?
Old Apr 5, 2011 | 01:15 PM
DeeGee's Avatar
DeeGee
I guess you always have to accept that the sensor sits in the engine bay but reads outside air temperature. It's always going to be off by a few degrees (on the + side).
Old Apr 5, 2011 | 01:38 PM
rdline's Avatar
rdline
mine no longer reads a new temp and stayed at the last reading of 60 degrees, thought that was strange
To Outside temp sensor
