front end drag
Old Apr 5, 2011 | 09:57 PM
buddyfew's Avatar
buddyfew
Default front end drag
What would be the pros/cons of raising only the front of c5 about half an inch. The drag is annoying.......
Old Apr 5, 2011 | 10:07 PM
jrose7004's Avatar
jrose7004
It's just the front spring loaded air dam. You'll get used to it.
Old Apr 6, 2011 | 12:28 AM
striper's Avatar
striper
There are no pros to raising it. The car is supposed to sit at a slight rake, lower in the front than the rear by approximately 1/2". If it's raised up you will reduce stability at highway speeds, it'd probably also negatively affect your gas mileage.
Old Apr 6, 2011 | 12:31 AM
vetteman741's Avatar
vetteman741
From: Motorsports Capital of the World..Indianapolis Indiana
Some people just take off the front air dam, that would be easier but it would affect the way your A/C condensor and Radiator get clean cool air.
Old Apr 6, 2011 | 02:56 AM
DeeGee's Avatar
DeeGee
You need the air dam to direct air into the radiator so removing it is a bad idea. As mentioned, its spring loaded so it absorbs any contact with the ground.
I'm not certain but I always thought that the stock bolts were fitted at the max height at the factory and that the only option was to lower the car.
Are you sure the car wasn't lowered by a previous owner? If so, you could go back to stock height. If you're just scraping on the driveway try going in at an angle. If its on regular roads I'm surprised if its at stock height. I only had problems over speed ramps in Vegas.
Old Apr 6, 2011 | 04:54 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Have you read your manuel lately???? This is expected by GM.
Think of that scrapeing sound as a good thing.
You could never be a NASCAR driver they are lower and drag
all the time.
To front end drag
