fbody gaskets
Old Apr 11, 2011 | 09:14 PM
baxsom's Avatar
baxsom
Default fbody gaskets
I am getting ready to start a headers parts list. I keep reading here that it is a good idea to use the Fbody gaskets because of the shape of the holes. Does it really matter? What do I look for just 00 camaro exhaust gasket? I know that there was a difference in the z28 vs SS so does it matter which gasket I get?
Old Apr 11, 2011 | 09:53 PM
slowtealz28's Avatar
slowtealz28
You can re-use your stock gaskets as long as they are in good condition. I am on my second set of headers and still on the original gaskets.
Old Apr 12, 2011 | 01:52 PM
baxsom's Avatar
baxsom
yeah, after 11 years i highly doubt it and stopping an install in the middle because of a 25 dollar gasket is a good way for a tool to get thrown
Old Apr 12, 2011 | 04:32 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
I went with the Fbody gaskets. I have them waiting to go in so if nobody posts up the p/n, pm me and I'll get it for you tonight.
Old Apr 12, 2011 | 04:45 PM
hattitude's Avatar
hattitude
When I installed my headers in April 2008, I used the F-body gaskets.
If I remember correctly, they have circle ports instead of square ports which are supposed to line up with the header flange better (or something like that)....
In April '08, the exhaust gasket part number was 126 17944.
But it had just changed from 126 00530, so it's possible the part number has changed again since 2008
Good Luck......
Old Apr 12, 2011 | 05:24 PM
87SAM's Avatar
87SAM
Good Luck......
They were still 12617944 last fall.
Old Apr 12, 2011 | 06:32 PM
baxsom's Avatar
baxsom
gotcha thanks, i found that number but it kept coming up every car GM made but the camaro it seemed. same as the part number for the bolt that holds on the 01+ dipstick tube. I had to call gene on that one.
To fbody gaskets
